Black Sheep LED Light Bar
The big issue for me is height too. This light bar sits at or slightly below the actual roof line. No issues there.
The only thing I wasn’t sure of was the wire management piece. I opted to use a cabling system (photo attached). Same I use inside the truck. I have no idea how these will hold up and if there is a better way or product, I’m all ears.
The light bar does not increase the overall height of the G. My garage is 83" tall and I can easily get in and out.
The wind noise is very slight at highway speeds.
You may have to have the light beam adjusted for best light coverage.
I just installed the Black Sheep light bar and whilst it was super easy I have just been told on the local Facebook group that it doesn’t comply with the switching requirement here in Australia as it should be connected to the headlight high beam relay.
So it’s unfortunately a case that whilst it was super easy to install it is seemingly non compliant with our ADR rules in Australia.
I have also taken some pictures to show the comparison with the standard headlights and the light bar at night.
Thank you for this.
Thanks for this info. I ordered this to conceal the wiring to the Black Sheep light bar and was very impressed with the final result.
Could you please post a frontal pic? I'd like to see look from the front. Thanks... :)
