AUSTRALIA: Third party suppliers for the Grenadier
DIFF BREATHER KITS (Air Parts Australia)
Diff breather kits from Air Parts Australia (3 choices) here.
A basic 4 Point diff breather (AUD75), a 4 point Pro version (AUD89) and a 6 point version (AUD85). Plus postage or free postage if your order is over AUD190. The 4 point Pro uses an Black Anodised Aluminum Manifold, the other two kits use a stainless steel bracket.
The supplied tubing has an outer diameter of 6mm and an inner diameter of 4mm. It can be written as 6mm (OD) and 4mm (ID).
Thanks to @DenisM for arranging this.
EDIT: GrenX has a diff breather kit under development.
The Zetifi combined mobile (cell) phone and UHF aerial is announced with details here.
Goes on sale 17 Feb 2025.
Reactions: Max
More goodies coming from EUROFLO Expedition namely rear window protection (look at the other images and you will see something else as well):
Revised and finished.
EDIT: SEE UPDATED LIST BELOW.
I have revised the wording for the diff breathers. I found the previous wording confusing, sorry about that. The new wording should be clearer. If any wording, in the thread, sounds confusing let me know and I can rewrite it.
I keep on hitting word limits meaning I have to reduce the word count and that can cause confusion also.
DIFF BREATHER KITS
Diff breather kits available from Air Parts Australia (3 choices) here. A basic 4 Point diff breather (AUD75), a 4 point Pro version (AUD89) and a 6 point version (AUD85). Look here for a selection of universal diff breathers available in Australia. If you buy a universal kit make sure your diff breather adapter fits the INEOS diff housing (M10 1.0 pitch) and the tubing is compatible with all parts of your kit.
WARNING: from time to time specifications change (in the links) and I am not aware of the change. Use the list as a starting point and check the precise details before you buy.
I speak from experience having made such a mistake.
Updated.
PLACE TO START FOR NEW OWNERS
  1. Download and use the Rok Dr Guide here. Print out a copy and keep it in the car;
  2. Grenadier Accessories (huge selection) for you to buy here;
  3. Kanvas bags and products here;
  4. Information concerning Deutsch DTP plugs here;
  5. Learn more about the CTEK SMARTPASS 120S and 250SE here;
  6. Fuse and relay thread here;
  7. Suggested Grenadier or QM fuses spares kit here;
  8. Littelfuse FHZ busbars used in the Grenadier here. It also informs you where all the busbar cables go;
  9. Finding the aux power outlets in the footwells here;
  10. Table describing all the available wire ends here (more wire ends if you selected the high aux power option);
  11. Various recommended torque settings here;
  12. L track information here;
  13. Oil filter part numbers and third party filters here;
  14. INEOS Air filter parts numbers and cabin filter here;
  15. Filter for Diesel water separator here;
  16. Understanding the NATO plug on the Grenadier here;
  17. What do you use on bolts/screws to stop corrosion, galling and seizing here;
  18. Thread on useful tools for the Grenadier or QM here;
  19. Guide to terminal crimping here;
  20. Anderson plug pitfalls here;
  21. Outback driving tips here; and
  22. Cheap battery monitors here.
INSTALLATION (OR HOW TO) GUIDES
  1. SEAT COVERS: Canny Outdoors video fitting seat covers here;
  2. SPOT LIGHT REPLACEMENTS: Mounting Kit of Exezit Lights here and KC Hilites here;
  3. SIDE MIRRORS: Installing SUMA Performance side mirrors here;
  4. WORKLIGHTS: XHQ Work light here, with installation instructions here, STEDI Work light here and here;
  5. REAR ROOF SHELF: Canny Outdoors video installing KAON rear roof shelf here and a Travel Buddy oven fitted to a rear shelf here;
  6. ROCK SLIDERS (ABNTR4X4): Installation video for ABNTR4x4 Rock Sliders here, with suggested improvements for tougher environments here;
  7. ROO BAR: Installing the Roo Bar here;
  8. ROO BAR LED LIGHTBAR: Installing a 20 inch Lightforce Viper lightbar under the Roo Bar Hoop here;
  9. UHF (CB) RADIO: How to install a UHF (CB) Radio in an INEOS Grenadier without drilling any holes here;
  10. UNDER-BODY ARMOR (RIVAL): Installing Rival under-body armor here;
  11. UNDER-BODY ARMOR (CUSTOM OFFROAD) BASH PLATES: The installation thread is here;
  12. UNDER-BODY ARMOR (CUSTOM OFFROAD DIFF PROTECTORS): Installing the diff protect5ors and trialing arm protectors is here and the PDF here;
  13. UNDER-BODY ARMOR (ERO FLO FUEL FILTER GUARD): The installation thread is here and the PDF here;
  14. SIDE STEPS: Electric side steps installation guide here;
  15. INSTALLING AFTERMARKET SPEAKERS IN FRONT DOORS: instructions here, German language install here;
  16. INSTALLING BLACK SHEEP NUMBER PLATE HOLDER (US/AU models with OEM winches) here;
  17. B PILLAR (DISASSEMBLING): look here with detailed instructions here;
  18. INGEMAR’S GRENADIER HOW TO SERIES here and here (e.g winching, offroad modes, diffs, etc);
  19. INEOS FORUM resources here;
  20. INEOS Fitting Guides here.
I will add it. Product says Grenadier only, any reason why it will not work on the QM?
I cannot see a link to the installation instructions, as yet.
The STEDI™ SMART Harness suited for the Ineos Grenadier is for those who are looking to run auxiliary lighting using the factory switch controlling the grille lights. This all-in-one solution is perfectly designed to be unobtrusive with specific crafted lengths to ensure adequate cable management.
Our aim was to create a stress-free installation process allowing for use in conjunction with the factory grille lights or as a standalone just for auxiliary lights. Giving you peace of mind of knowing it will come together in the end.
  • Featuring a total of 4.8 meters of wiring (fully extended)
  • 2.4m of cabling from Relay to Switch
  • 2.0m of cabling from the Driving Light connector to the Relay
  • 2.0m from H4 or HB3 Adapter to Relay
  • Total cable length 6.4m
  • 12vDC 35A Rated Fuse Kit
  • 12vDC 60A Switching Relay
  • Push Button ON/OFF Switch
  • UV Rated Insulation
  • Instruction included.
LED LIGHTBARS, LIGHTS, WIRING HARNESS, ETC.
In Australia popular brands of LED lights include (in no order):
  1. INEOS (LED Lightbar);
  2. Lightforce (Spot lights, LED Lightbars and work lights);
  3. ARB (LED Spot Lights, LED Lightbars);
  4. Ultra Vision (Spot lights, LED Lightbars and work lights);
  5. FYRLYT (Halogen Spot Lights);
  6. Teralume Industries X Strip lights. Stripe lights also available at DRIFTA, PDP and ÓFFROAD Living (White and Red light model);
  7. Expedition HQ Camping lights kit;
  8. Laser Lights Australia (LED Spot lights, LED Lightbars and work lights);
  9. Perception Lighting (Spot lights, LED Lightbars and work lights);
  10. The 20 inch Narva EX2 double row lightbar can be attached to the top hoops of the Roo Bar using the Narva 2 inch tube mounts (Part #72296). Look here;
  11. Great White (LED Lightbars);
  12. STEDI (LED Spot lights, LED Lightbars and work lights); and
  13. WIRING HARNESS: The STEDI™ SMART Harness for the INEOS Grenadier is for those owners who are looking to run auxiliary lighting using the factory switch controlling the grille lights here.
