AUSTRALIA: new standard for lithium batteries coming
TheDocAUS
3:32 AM
Eromanga
From November 2023 all batteries used in recreational vehicles in Australia must (which might really mean may)* comply with Australian Standard AS3001.2:2022. The link is a summary of the standard. It applies to Lithium, Lead-Acid batteries etc. It is worth a read. More info here.
If your battery does not meet the new standard, it may impact your insurance policy, in a worse case scenario the insurer may deny liability. So check policy wording - I really hope it is not added to Policy wording (but insurance companies love a good escape clause).
Here are some interesting requirements:
Lithium batteries
“These instructions must include a directive that installation work needs to be completed by an appropriate person (eg licensed electrician) according to the electrical legislation of your state/territory jurisdiction.”
Lead Acid
“A spill tray must be installed under the battery(ies) that can hold a minimum 20% of the electrolyte held by the battery(ies).”
Invicta Lithium batteries are saying they comply with the new Standard, but the Standard goes beyond the battery to include fusing, securing the battery, etc.
IMPORTANT DISCLAIMER
*We need to find out whether this new Standard is compulsory or optional. Usually, Standards are not compulsory (if they are put in a Code under legislation they can become compulsory). For the time being it is probably not compulsory, but that does not mean they cannot be put into an insurance policy. It may become an issue over time, as we live in a world where people love to change optional to compulsory.
Standards Australia's FAQ states:
Are standards mandatory?​
We publish voluntary standards. However, State and Commonwealth governments often refer to standards in their legislation. When this happens, these standards can become mandatory.
We are not able to give advice in relation to the compliance or non-compliance with any requirements or specifications in a standard. Please contact the relevant regulator for information on compliance with mandatory standards. A list of key government contacts is available here.
From November 2023 all batteries used in recreational vehicles in Australia must comply with Australian Standard AS3001.2:2022. The link is a summary of the standard. It applies to Lithium, Lead-Acid batteries etc. It is worth a read.
If your battery does not meet the new standard, it may impact your insurance policy, in a worse case scenario the insurer may deny liability. So check policy wording.
Lithium batteries
Lead Acid
Thanks for the "heads up" @TheDocAUS (y)
Wasn't sure where the link was so here's a bit more info:
Would be an informative exercise to determine who the subject matter experts were who advised Standards Australia on this issue and their commercial links (if any):unsure:
I wonder if that's to be retrospective?
The lead acid one is interesting. Most battery installations (both OEM and second set up) hardly have enough room for the battery, let alone a tray that can hold 20% of the acid therein.
Places like ARB, TJM, etc etc are going to have to employ a sparky now by the look of it, not just an equipment fitter..
Standards are not generally retrospective.
But the requirement about battery compartments may (or not) impact the IG. Before anyone asks, I believe INEOS Australia are looking at the issue.
How the standard applies to the IG may depend on the exact wording of the standard. The devil is in the detail, but I do not want to pay $200 for the Standards exact wording.
A third party battery box may be a “battery compartment” under the Standard requiring it to be externally vented. I would like to know the answer to that question, because:
Standard also applies to inverters.
For other vehicles, Interesting to see the definition of auxiliary batteries, ie. those installed third party to run a fridge etc etc, given they are not related to vehicle propulsion or compliance with road vehicle regulations.
Technically as I understand it the IG aux battery is installed to support the starter, so they could potentially dodge that bullet, but any modification to that, for example to isolate the starter and have the aux solely set up for running a fridge, could well be trapped potentially.
I have already read one email saying the new Standard is compulsory by saying you "must" comply, but is that a marketing ploy?
Insurance Companies would be daft to insure homes that have had older battery systems installed, where a fire separation wall is not immediate to the home. One went up the other day in North Gold Coast - good old fire... not sure on brand of battery wall pack but obviously had issues.
The safety police are everywhere and that is not a bad thing.
My auxiliary needs are not great. And I won't be living inside the Grenadier.
At this stage my plan is to use my Kickass battery box with integrated DC-DC and substitute the AGM battery for a Lithium.
The box suits either type, and has been properly engineered (certainly not under-engineered) .
Solar is plug and play , and there are more outlets than you ever need.
I will either mount it in the cargo compartment (it is easily detachable) or if possible/safe, mount it to the rear seat back (when folded forward).
Hopefully I can satisfy all these new standards and the need for an expensive wiring professional.
If not , well just another one of life's obstacles to overcome , eh!
At present the Standards are optional for owners. But people love to change Optional to Compulsory.
Uh oh.. I've seen a lot of caravans with Lithium batteries under the floor!
I have seen a garage go up in smoke only a week ago, closed a rural east-west main road and I was forced to drive an hour in M1 traffic to get around it! They shut the damn road!!!
Apparently 60kWh of Lith battery storage went up!
Enerdrive system built to comply. They've used filtered vents in the door to stop dust ingress, and a Dometic roof vent to aid in convection ventilation. $$$
After reading the Standard I remembered that video and understood why they did it.
Your post needs an edit "BIG$$$". :)
Thanks for the info Doc. In your link it states that the new standard is made mandatory by electrical legislation in each state/territory
That is not definitive, but it strongly suggests mandatory is on its way. We need to see who the legislation applies the mandatory obligations too, it may only be caravan makers.
Take a look at this article from BMPro (12 Volt Guru), its application maybe even broader than quoted above (like fuses on solar panels, inverters, RCD, etc). We do need to know what Recreational Vehicle means, as the standard applies to them (pretty sure it does mean caravan, camper trailer and motor home - not sure how far beyond that).
An earlier article by the same 12 volt Guru states (in part):
Although the new standard has already been implemented, it will only be enforceable on new RVs starting from mid-November 2024. While there won’t be any 12V police patrolling caravan parks to enforce strict compliance, there is a clear expectation on Australian manufacturers and importers to adhere to the new Australian Standards. It is also anticipated that the industry as a whole will hold itself accountable for identifying and addressing non-compliance issues.
As clear as mud.
