Diff lockers arent just for greater capability. When used properly, diff lockers lessen the stresses on the drive train, and also aid in treading lightly.
I don't know why you couldn't. But, you should have already engaged them.But, if you find yourself stuck in mud (as I have been in clay in our D3) can you even get the lockers to then engage once you are stuck?
The range of motion is a square, not an H per se... Your agent should have thoroughly gone over and demonstrated everything to you. Honestly, the first few dozen shifts between high/low and lock/unlock will take some effort. Just make sure that whatever position it is in, the collar is fully down and seated. High to low will take more force than lock to unlock (or unlock to lock). If it doesn't want to go between high/low, let the vehicle roll a meter or so while in neutral and try again.I only have the center diff. It is still very stiff to operate the lever. Am I trying hard enough or suffering from operator error?
Is the transfer gear change gate an H shape?
In neutral, lift collar and the stick will move left but not down.
Having moved left, going up into H is straight forward but down into L is very hit and miss.
Thank youThe range of motion is a square, not an H per se... Your agent should have thoroughly gone over and demonstrated everything to you. Honestly, the first few dozen shifts between high/low and lock/unlock will take some effort. Just make sure that whatever position it is in, the collar is fully down and seated. High to low will take more force than lock to unlock (or unlock to lock). If it doesn't want to go between high/low, let the vehicle roll a meter or so while in neutral and try again.
