Amazing aftermarket audio system/speaker upgrade
I am strongly considering the V4M system - with the sound-deadening foam and replacement A-Pillar tweeters, but without the BT module and without the sub/bass knob installed in the upper panel. I received one installation quote so far from a reputable shop in Escondido, CA..... nearly $2,000!!! Good gravy, that sounds like robbery. If anyone has a recommendation for an installer in North County San Diego, post up please.
Do it yourself IF you have a lot of free time. I am not a big DIYer and so far I am half way through it. I've done all four doors, and I have to say the sound proofing makes a huge difference. I still have to install the amp, sub, a-pillars and wire everything up. I anticipate this would be much easier than the doors. The first door took a while but each door after that was quicker. With the amount of clips I broke on each door I highly doubt a shop would have replaced them correctly. I pre-ordered door clips from my dealer but those were not enough so I had to jerry rig trim clips into door clips. Another huge bonus is that you can completely sound proof the floors while you are doing the install.
How many hours do you reckon it will take you, all-in? The shop I got the estimate from arbitrarily estimated about 14 hours, which seems excessive for folks with heavy experience. If I DIY, my time, these days, is essentially free, but my patience is not. :)
For reference, if I'm not wrong, Car & Audio (Bjorn's company that supplies the system), appears to charge roughly $800 for the install.
Great advice on stocking up on extra door clips if I go DIY!
I will tell you how long it took me so far, but keep in mind that i am also a bit OCD with cutting and installing sound proofing. Looking back i wish i just slapped everything on and stopped worrying about it.
First door: 4 hrs
Second door: 3 hrs
Last two doors: 2.5 hrs each
Estimate for installing the rest which i haven’t done yet:
A-pillars: 1 hr
Amp/dsp: 0.5 hrs
Sub: 0.5 hrs
Wiring (removing trim): 3 hrs
While doing the doors, i definitely wish i did not start the project. But looking back - i am glad i did because i learned how doors work lol.
Thanks very much. I suspect my time would be not too far off (which is more than I want to dedicate). I think I will keep trying to find the right installer. (y)
First door: 4 hrs
Second door: 3 hrs
A-pillars: 1 hr
Amp/dsp: 0.5 hrs
Sub: 0.5 hrs
Got to ask? Do you have a car trim kit? Basically the tools to remove trim and limit clip breakage?
@avidtest Like I told you by Mail. For it sound like robbery too. No speacialized Car Audio installer will never ever need 14 hours for the install. What time we need I told you in my last mail. Theres a huge difference.
For all others. If it helps we can offer a set of door clips for 5$ extra. So you don´t have to search some if some will break while installation.
What about a panel removal kit? Is it interesting to offer one too?
I have a whole kit but I think offering it is a excellent idea.
Thank you SimSound- I'm in process of obtaining some more quotes from installers at the moment. I can tackle it myself, I just prefer not to. :)
First door: 4 hrs
Second door: 3 hrs
A-pillars: 1 hr
Amp/dsp: 0.5 hrs
Sub: 0.5 hrs
Any tips on the sound proofing material? Now that the door panels are coming off to address the lock recall - sound proofing is more doable.
The system came with an installation guide that details which material to use on different parts of the door. Before you start a sound proofing project I would get familiar with different materials and their uses. The resonix website has been a useful guide for me in the past, you don't have to buy from them - it just gives a general idea.
How loud does it make at ADAS clicking?
@IslandFalconer When you use our system (V3 and V4M versions) you can change des master volume with our DRC controller. In normal daily use the wanring chimes (Ice warning, seatbelt warning, door open, dc, etc.) is as loud as now or if you reduce the master volume more even less loud as in factory standard.
If you like to hear music with the systems max possible volume you can turn the master volume on the DRC to it´s maximum.
This is the perfect solution to have a powerful system and also "normal" loud warning chimes.
Grenadier V4 Masterpack Link
I’d prefer if you could eliminate it all together.
Ordered the V4M from Bjorn (SiMsound). Although not my forte, I'm leaning on tackling the install myself. Very much looking forward to a big sound improvement!
Finally received the entire system (USPS lost the first subwoofer and @SiMsound sent a replacement - thank you Bjorn). Got the doors done a couple of weeks ago. Now for the rest. @SiMsound or @acaciolo , can either of you confirm whether the DRC power/bass knob should still be installed even though I'm not installing the standalone bluetooth module?
