Alternator & Aux Battery
Start stop is awful when towing. Turn it off when you are able to. JLR do give you a switch.
How does hosing out the floor work with the batteries?
Not many would ever actually hose out the floor. But you could use a hose to wash off the grime after washing the mud etc off with a brush.
If you splash water on the console , shifter etc you might have some problems.
And I believe the battery enclosure is sealed at floor level.
All in all far better protected for river crossings than vehicles with electrics under the bonnet.
I thought I saw something (can't recall where, so much I've looked at the last 2 years), that the center console, switches and even the shifter were splash resistant, meaning ok for a spilled drink, for example, but don't pressure wash it.
Yep, I have forgotten the actual IP rating number, but yes they are rated to be basically splash proof, you dont want to hose or submerge them but they will withstand a splash or some overspray etc.
Spilled lemonade killed my phone in the early stages of fighting a big bushfire at our place years ago. No contact with outside world for 10 hours , until a policeman turned up because relatives were concerned.
No sugary drinks in the front of my cars , thanks!
I use sugar free beverages not for dieting but because buttons never get unsticky.
This might be an option since it is also an engine starting battery.
DCS 12V 110AH (LITHIUM)
12V 110AH Lithium Ion Battery | Deep Cycle | Engine Starting
DCS Batteries are the ideal replacement & upgrade from AGM, Gel or other lead-acid batteries for any application. DCS gives you the ability to upgrade your current batteries to lithium-ion technology that can deliver a minimum of 2500 cycles and has tremendous advantages in weight, performance, reliability and service life compared to traditional lead-acid batteries.
Backed by a 4 year warranty.
I was viewing an INEOS Trailmaster today in Sydney Australia (Purnell Motors) and the INEOS rep was also present. He was strongly against using a Lithium battery in the car, I suspect one cheaper brand popular in Australia (Perth based). The rep was involved in the homologation and ADR approvals in Australia, which took around 8 months.
I was viewing an INEOS Trailmaster today in Sydney Australia (Purnell Motors) and the INEOS rep was also present. He was strongly against using a Lithium battery in the car, I suspect one cheaper brand popular in Australia (Perth based). The rep was involved in the homologation and ADR approvals in Australia.
Interested in his reasoning why he didn't recommend a lithium in the IG
He was guarded in his comments, but stated Lithium batteries were not part of the approval process for the Grenadier. When pressed he seems concerned about a brand of Lithium battery used here in Australia (which I would not use). I would consider using an Invicta Lithium battery which is a proven brand.
I was surprised with the conviction behind his view. Suggesting he may know more than he was prepared to say.
I think I know of the brand (orange top) is this a start battery or aux he was talking about?
