35's with the Eibach 2.5" lift...
Did you install the fox sway bar? I just got all my stuff installed and noticed some body roll that wasn’t there at stock.
Set up is Eibach - steel 17”s -285-75r17 - Alex @ Overland Garage did the work. Hope the Eibach settle little softer ride felt harsh on the drive back - need to get TPM’s set to better PSI 38 front - 42 rear for highway driving.
Possible to have a quick phone call? Would love to pick your brain about the lift / tire size and factory spring differences
Ill sell you the Eibach springs and steering stabilizer — Im retuning it to stock I think….if the tires dont fit I might need to sell those too.
Hey TravelerBT,
I’m having my Eibach 2.5’s and KM3 LT315/70/17 (inches) 34.4/12.4/17 BFgoodrich mud terrains put on next week. I currently have 295/70/17 with stock suspension with no problem. The shop that is installing the springs has already done this and had no issues. Will let you know first hand when installed.
On a second note; I spoke with Eibach USA and they relayed to me that they now make a pro-lift-kit in the US (model number E-30-34-001-06-22) that works with either winch or no winch, and is in stock! It’s all very confusing but this will level and raise the car with 2.5” front / 1.2 rear.
Asjtex, which shop did you use?
View: https://www.youtube.com/watch?v=TR-arT4QNaM
I'm looking for a similar look to the above, but with different style and spec wheels, 17x9s and ET0 for a bit of poke.
  • Are there any reputable shock vendors that pair well with the Eibach 30mm springs?
  • What is the in spec range for caster and what caster are y'all able to nail with the lift?
  • Any noises from the added angles on the drive shafts due to the lift?
  • Any drop brackets and the like to add clearance between the control arms and the sway bars?
  • Is a regear a good idea with the 35s?
  • Any solutions to account for the added static and dynamic loads from running bigger/heavier 35" tires on the rear door?
I come from the solid axle Land Cruiser world and to do it right, it's quite a few parts necessary to make it all right. New world here with the IG for me.
Thanks!
  • Nothing for sale as of yet, Eibach is working on a set of remote resi's for the US lift, and King has a set that I don't believe are released yet, but were designed around the stock springs
  • 2° is the factory setting
  • Can't comment, no experience; but there are a few people that have had driveshaft issues with the US Eibach lift
  • No drop brackets exist
  • No regear setups exist
  • From the people running 35s, nothing has to be changed with the door (other than the bracket); the inside of the door is seriously braced from the factory
Regarding caster, does anyone actually have an alignment spec sheet post-Eibach 30 mm lift they can share? Gracias!
Wow, several pages of “secret” information in that thread. Golden. INEOS should be sharing this with owners directly. Wtf. *cough* shop manuals *cough*
