Americas Wolfbox is installed and it is very cool
I just installed the G990 pro and thought I would post incase it helped someone. Prior to install, I researched all the threads and watched all install videos I could find. I was still unclear on the exact procedure to fish the wire through the rear door boot (specifically the door side of the boot - this is the hard part). In two of the "pro" install videos, the hardest part of the install was skipped and it seemed like the installer actually made a hole in the door side of the boot after the weather seal portion.
Well, after thinking it over I finally came up with the exact procedure to do this WITHOUT damaging the boot in 30 mins or less.
What I used:
Cat 5e cable I had laying around (cut off the ends)
Klien tools 51100 foam lubricant
Gorilla tape
1) Remove both ends of the rubber boot. Remove lower door panel.
2) Remove all white clips securing the factory wire harness from the for frame. This will allow you to pull the wire harness out of the door side boot hole so you can expose the electrical tape. Remove electrical tape that secures harness to rubber boot (door side).
3) Get comfortable with rolling the rubber back from the harness.
4) Roll rubber back, place the foam lubricant tube and roll rubber over the tube. Discharge lube. Push the lube tube further and discharge again (do this a few times). Also insert lubricant tube on the other side of the boot and discharge. The goal is to get everything nice and slippery.
5) Take the cat5e cable (with trimmed ends) and insert on the door side of the boot (using the same procedure used to insert lubricant tube).
6) Once cable is in the boot slowly keep sliding it in until you can find it on the other side of the boot.
7) Pull cable until at least 5 inches of cable are exposed on the other side.
8) Clean the lube of the cable throughly, duck tape at least 5 inches of cable and 5 inches of the camera cable (with a continuous piece of duck tape).
9) Take your time and fish the camera cable through the boot (I am talking like 1mm per second)
10) Do not remove the duck tape after you fish the cable through, there will be another rubber grommet that your can fish through using the same procedure.
Very nice. Thank You for taking the Time to document and post this instruction. I routed it the ugly way along the gas strut. Could not find the cabin end of the rubber gasket and was to impatient to dig into. Your post would have helped me a lot. Thanks.
Anyone look into the "mirror" and night, and for an instant think the fuzz just put their lights on, due to the refresh rate on the screen and led marker lights?
Yes, I have noticed this. Think it may be brand specific? It was a Kia and Hyundai that I noticed..
I get the notification to format the SD card everytime I get in the car and if it is a long drive I have to format it while I am driving. I wish it would allow a larger capacity SD Card
Might be worth changing out the SD card and seeing if the fault is still there. I don't have that issue.
I am not 100% happy with the way the rear camera is mounted.
1) It changes its angle every time the door is slammed. Tightening the screws does not permanently solve it for me.
2) Sun flaring is an issue.
3) The camera should sit a bit higher to avoid the window heater cable going right through the image.
Trying to fix this with a 3D printed mount for the camera....
I had the same issue and used 3m double sided sticky pad and that holds it in place now.
I have not had that issue since I used the 3m sticker to hold it up and whether by luck of judgement no lines appear on the mirror.
I did too until I grabbed the latest firmware. That problem has now gone. However, I have a new problem where the every couple of days when starting the car, the mirror alignment that uses the white circle where you can move your finger over it to position it., keeps returning to the top and I need to bring it back closer ot the middle again.
I'm just dropping a note here for reference that I posted a lengthy soup to nuts three part exterior roof mount G900 install guide in my build thread. I was going to post it here or in the vendor thread, but it became so long that it was easier for me to manage in my Build thread. Here's the link to Part One in case it can help anyone else out.
Anyone else get the three channel WolfBox G900TriPro preorder email? I wish that had been out before I installed my G900Pro... I like the idea of an in-cabin view in case of an accident to prove I wasn't on my phone or asleep at the wheel.
Yes i got it but unit oil they release a firmware update to get rid of the damned WiFi splash screen during drives I would not buy any WolfBox product.
View attachment 7888504View attachment 7888505
I would certainly like to see this come to life! Keep us updated
That wifi pop up was frustrating. I'm pleased that they fixed it in the last firmware. I haven't seen it since I moved to the new one.
Any hope of them bringing back the ability to horizontally align the back up lines. Afraid a valet will back in to a pole.
I've already got the 2-channel G900Pro and I haven't had any issues with a pop-up Wifi screen. It definitely sounds like an annoyance and borderline dangerous thing to have pop up while driving. Glad to hear that @DoubleDoom has had good luck with the firmware update...
I don't think I can justify getting the 3-channel so soon after getting the regular Pro.
