Winter prep
New Grenadier owner. I have lived in Bend, Oregon at 3800 feet the last 10 years. The local ski resort is 15 miles from home. Lots of snow, ice and 20,10 and some 0 degrees in our long winters. I am also reviewing snow tires vs staying with the ko2s. I have driven a jeep Jk here the last 10 years. Lot of time spent on Ko2s. My personal experience with these tires is thery are OK in fresh snow. Weak in packed snow toped with ice & black ice. I also find them ok to negative in wet weather. Not a lot of driver road feed back and prone to breaking loose. Also the tire compound used in these tires changes as the wear down. Best new to 25% . The tires compound is different the last 50% and becomes much harder, which further degrade your experience in wet and winter conditions. If you only drive local and a few day a week, you can get by with them in winter months knowing there strength & weakness. My wife votes for a winter tire change. For a daily driver, winter tires are much preferred, and location with lots of packed snow and ice studs studs a strong consideration when allowed. The Falken wilkpeak at3w or Mickey Thomson Baja Boss all terrain tires in my option are a better wet weather -snow option for year round all terrain tire use. For winter tires Nokian Hakkapelitta regular and studied tires get my vote. Regular for use in use when mixed road condition are common. Wet black top no snow and snow/ ice at higher elavation. Local driving in snow and ice studded are a premium experience. Of course offroad driving tire condition Ko2s are a strong performer and a top choice. KO3 are just being offered and rumored to be a different compound and tread design which for snow and wet weather may become a winter/ summer at terrain option tire choice.
I am not too far away in Parkdale and will be purchasing
I am not too far away in Parkdale. I will be purchasing Nokian LT3 studded for my winter driving. I have had other hakapelita Nokian tires and was concerned about sidewall strength. This one looks a bit more beefy. Nokian says :
"strong structure and superb durability for demanding winter use."
Those were my top choice - availability was just a little bit of a pain so did Blizzaks. Not the studded though - worse handling and braking performance for days when the road is dry
I live at 7K ft in Colorado and Snows are key. I just had my "handover" yesterday so I'm new but it seems that I have read that dealing with the TPMS can be difficult when changing tires. Do you have any thoughts on this?
I have a spare set of wheels and snow tyres, got a set of universal tpms sensors cloned and they work fine, have the corner written on the inside of each wheel so I know what goes where and it’s all good 👍
Are some good inputs in the forum from folks who have bought sensors, cloned them, gotten vehicle to recognize (Autel MX - can search). I'm sadly not that savvy, so do have the same issue wanting TPMS in my separate wheels (I have separate winter wheels and tires, but last season had to use original TPMS and remove/intall); hoping to get this fixed as will put winter set-up on in 4 weeks.
Generally do my tires at discount tire (who are not particularly specialized!). And with newness of the vehicle, has confused them. In addition to the crazy Ineos set-up of having the sensors not be auto-recognized by the vehicle. Nice folks, but this vehicle set-up is not normal for them.
If someone has a shop (non-dealer) who does this effectively in the Front Range (I'm in Denver), I'd gladly go there. Just haven't spent the time hunting for one.
I haven’t installed my winter wheels - purchased them (Black Rhino’s with Blizzak LT’s) but won’t install until November. Have a truck wheel specialist doing all of it. He called his Black Rhino dealer and they walked them through how to clone the OEM sensors. Don’t do this at Costco. And, as @Baron von Teuchter recommends, just label them so you keep them straight for the following season. Now if I could only talk my guy into storing them so I don’t have to schlep wheels back and forth twice a year . . .
Heavens opened last night and Autumn is finally here. Tyres needs inflating and TPMS reset. Topping up both coolant levels so that the heater works to get rid of condensation. Never had an issue with my safari windows but yesterday whilst sat in the car, I could see a bead of water forming below the seals. Which reminded me this morning to take out both windows and clear the drains. I also pressed down on the drain holes and smoothed out the sealant to try and make it flush. Personally I think the drain should be flush and not raised like it is. Preventative maintenance.
I also used a specialised car rubber seal protectant on the safari seals after cleaning the layer of sticky dust from the opening, glass and rubber. (I'm sure that makes it leak)
Made me think to redesign the seals. If the seals have an additional flap or a wing to cover the aperture then no debris or water would get in. 🤔
The sunroof and seal design pretty much says 1974. Not much more to expect, but keeping the seals clean, supple and in perfect condition is important.
Albeit a 2023 model, I don't think the assembly line operators were adequately trained on safari seal adhesive.
A bit more sealant would have been logical
