Mines the opposite. Whines under load and quietens down when backing off. This is the second TC if had in her and is better than the first, but still disconcerting.
Hi all,
Is a dull whine noise when decelerating ( coasting) normal for the Grenadier ( diesel)?
I only notice it if I’m driving over 70k’s per hour and it goes away as soon as I touch the accelerator.
I've noticed across 4 loan cars and mine in the last year that the gear whining is louder when the car is new. Henry is perceptibly quieter in this respect now than 12months ago on delivery.The apparent "whining" in the transmission is a defining characteristic of "straight cut" gears used in the transfer case.
Check out this relatively short but helpful explanation: https://www.carthrottle.com/news/advantages-and-disadvantages-straight-cut-gears
The Tremec company have been making race car straight-cut gearboxes forever and hence their incorporation in the IG transfer case is no surprise.
The "super V8" series at one stage mandated a "control" 6 sp straight cut gearbox supplied by Tremec. ...(perhaps they still do) Sometimes the in-car audio would pick up the whining noise which was sufficiently loud to draw the attention of the race commentator ...
Thanks for the explanation, Denis. I wasn't aware the Grenadier transfer case had straight-cut gears and was thinking I had a diff problem.The apparent "whining" in the transmission is a defining characteristic of "straight cut" gears used in the transfer case.
