So the CV joint shat itself big time!
Not as yet TomAny idea if it was the front or the rear shaft?
That doesn't look to me like a cardon joint but more like a homokinetc joint, not bad...but why has it failed? Too much play? Too less lubrication? Too much power? Too much lifting?I have just now read on FB, of a person on holiday in Romania. He has just suffered catastrophic failure of the Cardon joint and damage to his gearbox. To make things even worse, support has not been good. He has owned the vehicle a year and 14,000 KM and to this point, had been very happy.
Indeed, a constant velocity joint, not a cardan.That doesn't look to me like a cardon joint but more like a homokinetc joint, not bad...but why has it failed? Too much play? Too less lubrication? Too much power? Too much lifting?
Too much force!That doesn't look to me like a cardon joint but more like a homokinetc joint, not bad...but why has it failed? Too much play? Too less lubrication? Too much power? Too much lifting?
...to shift the weak point somewhere else and to break there in the future...yes, I know...a never ending discussion.Too much force!
Bigger wheels, fully loaded , wheel drop from a great height is my speculation.
As you know , you can break any part offroad if you push hard!
And then the aftermarket steps in , with stronger components...
I think the Grenadier is pretty tough for most offroad applications....to shift the weak point somewhere else and to break there in the future...yes, I know...a never ending discussion.
However, you're explanation sounds feasible. Am I wrong when I say, the material should cope with such modifications (as long as they are not extraordinary)? or teh weak point should have been more to the wheel hub by design?
It is simply plugged in? Not mounted in any way? No bolts, rivets, welding,construction foam or some kind of spell?The CV joint is not broken, the shaft has came off the splines.
Where is the traditional "sliding joint" in this propshaft? If that has seized it could cause shaft coming out of splines.
Suspension lift may have some effect on the sliding joint (where ever that may be).
