What is this clip?
6:20 PM
Denver, Co
Crawled underneath my car to see if I can diagnose the metallic rattle on the driver side.
Found a plastic clip loose and freely sliding along this shinny plastic line above the front drive shaft. The clip itself can touch the drive shaft, depending on where it’s positioned.
MTNDOG
5:20 PM
PNW #359
MTNDOG
5:20 PM
PNW #359
Not sure 100%, but it looks like. The one in the thread i quoted looks like it broke, where yours looks like it should go back together??
globalgregors
11:20 AM
Sydney NSW, Australia
If it’s any consolation this clip broke on ours on the first country drive. They’ve changed the cable runs under there since vehicles as early as ours so this may not apply… but we have more than a couple of cable ties keeping things squared away.
6:20 PM
Denver, Co
I just realized there is a zip tie holding the cable away from the drive shaft.. as such, there is no way for me re install the plastic clip.. The cable is fairly stif.. So I simply cut the clip off.
Skydance
1:20 AM
MANCHESTER
It normally happens to all. Those clips are under too much tension and is useless. When you clipped them back together, as soon as put it into low range they come apart again. Zip tie is your best friend. No point taking it to the dealer. Common issue.
anand
8:20 PM
Maryland
This... All of this.... Your cable should also have a ziptie near the transmission, that's the "OEM" fix for it...
