Working on different options to mount my GMRS radios and phone. With advice from a few members on the forum I found a good spot to mount the ghost antenna.
Mounted the radio unit under passenger front seat.
1.3” front spring spacers from Shadowmarq Industries finally on. More level stance and a bit more room for the larger tires without the increased risk of driveline issues with the 1.7 or 2.5” Eibach springs. Front shaft pinion angle is just fine.
Also, Wolfbox 900 Pro.
Shadowmarq Industries. - I pre-ordered the spacers with them. I don’t think they have them on website yet but you can contact them by email or website inquiry to order a set.
And 2 more things...
I have the sun shades for the safari windows. But they always flop around in the trunk. I had the @OverlandGearGuy build me a storage bin for them to be mounted under my trunk shelf. I'm pretty happy with it, I may add a strap across to compress it a bit more when closed but I'm digging it.
Second thing is my custom license plate. PUB 4X4 is yours truly if you see me on the road.
Then a little time getting to know the VAAST water tank system. Easy install and the product seems to be perfect for my needs.
I really like the look of the vaast. Let me know how it goes.
How was the install on the spacers?
View attachment 7876225View attachment 7876226
LP is legit!!!
Interested to see how these go. I am planning on welding steps onto my sliders.
I'll put progress up on my build thread. I'm not a real metal worker and am making stuff the easiest way which is using RHS that I have lying around from other projects.
We went to the local markets today to get some fresh fruit & vegies.
Left the car parked for about an hour with the dash cam recording and the fans were going after a dpf burn when we pulled up.
When I got back the red low battery warning was on but I have the dual battery system so it started straight away.
Battery was down to 51% but within a couple of minutes of driving away it started to climb and was charging at 117 amps.
I have seen it go that high when in the low 80s. This car knows how to pump out amps when needed.
