What are IG's 4 Gear Mode Recipes?
Grenadian
8:37 AM
Korea
Hi, Dear
I need a detail of the 4 gear modes of IG.
High / High Lock / Low / Low Lock
My IG has become much smoother in the movement of the transfer case than before.
However, there is no proper usage situation of the 4 gear modes in the user manual.
I need education.
Very Thanks.
6:37 PM
Rhode Island, USA
Hi, Dear
I need education.
Very Thanks.
From the manual…
Not sure exactly what you are looking for beyond this?
Reactions: Sal
landmannnn
11:37 PM
Hi, Dear
I need education.
Very Thanks.
In simple terms
High - normal roads
High lock - gravel tracks
Low - Slow and steady such as manoeuvring a trailer
Low lock - proper off road conditions
Grenadian
8:37 AM
Korea
In simple terms
High - normal roads
Thanks a lot, What would I choose snow or a little ice?
6:37 PM
Rhode Island, USA
I’d say “it depends”. The center differential lock gets you more traction at the expense of steering. If you are driving on a snowy or icy road, I’d probably leave it unlocked until I found myself in a situation where I was needing more traction say to get up a hill… then I’d lock it to push through.
Reactions: Sal
bemax
12:37 AM
If driving on a proper road without steep ascents you should stay in high without a locked diff. The Grenadier has a all time 4 wheel drive so you are prepared for some slippery parts if you have the momentum of a decent speed. Normally you shouldn’t notice a spinning wheel in such an situation.
Reactions: Sal
6:37 PM
Pittsburgh
high.
low will amplify the tq to the wheels which is not ideal, and any locking will force a tire to break free on a turn, which again is not ideal.
Two nights ago I was fiddling with the gear shifter and it permitted me pull away in second gear. That would be your ideal on a slick surface, and has the added benefit of you controlling the shifting and tq to the tires. I'll have to test that again. These trucks have a ghost in the machine, and there's no telling if that was a one off or it's programmed to allow it.
Reactions: Sal
Tom D
11:37 PM
Berwickshire
Centre diff is good for loose traction surfaces even if you dont “need” it go go forwards. It improves handling. Gravel roads for example or packed snow. It also massively improves braking performance on low traction surfaces as due to the brake bias the front wheels are more likely to lock up, with the centre diff locked braking force is shared between all four wheels. Same with packed snow.
Reactions: Sal
CrazyOldMan
5:37 PM
Wisconsin, USA
high.
Icy paved roads correct - you don’t want spin on the tire from a stop. My third scenario (deeper snow off-road) would I go 4L and manually control the gear. You want to ooooooze out of that position. Also - I keep snow socks for the tires just in case.
