Volume Controls
4:29 PM
Florida, USA
Going through the audio volume controls and trying to figure out the list below. What do each of these control specifically? They are not in the manual.
Vehicle Start
Volume Minimization
Speed Dependent Volume Control - Assume this is for automated high speed volume control.
Increase Notification Volume
Input Sound
Warning Sound
Any way to control the volume of the annoying speeding clicks?
Vehicle Start
Volume Minimization
Input Sound
Warning Sound
Hi there and welcome to the forum. Do a search of ADAS and you'll find a maelstrom of threads about the clicks, beep, etc. There's a "shortcut" using the FAV button to get to an ADAS screen where you can disable several of these annoyances. Your dealer may have already set that FAV for you (it seems most are).
Vehicle Start
Volume Minimization
Input Sound
Warning Sound
Vehicle Start - set volume to a set number. IE - you're driving home from work on a beautiful day - windows down, safaris out, and music blasting. When you go to start the truck in the morning, that volume is a bit too much (we've all been there!) - so the truck will default to your volume level of choice upon start.
Increase Notification Vol - that just makes notifications louder/softer
Not too sure about the others.
Speed Dependent Volume Control will increase the volume of your radio based on your vehicle speed. This basically allows the truck to automatically adjust the volume up to offset for wind and road noise. Then when you are back at a stop, the volume readjusts to the original lower level. So the higher this setting the greater the volume increase at travel speed.
This has stopped working. Currently set to zero, but volume still come on with vehicle start.
I just noticed the "warning sound" in the menu and wondered what it does. I set mine to low but still don't know what it affects.
Rebooting this thread .
Has anyone worked out what the "Volume Minimisation" Setting in the volume settings menu do?
I was playing around with the volume settings today and it didn't seem to do much.
Cheers
Steve
Another reboot. I sent a email to Ineos support today and got the following reply. The only thing i can add is the startup volume also sets the radio volume as well. Will add this to the next manual update.
Cheers
Steve
