US Trailer hitch problems
ZemTyrion
3:35 AM
Denver, CO, USA
I'm just wondering if I'm the only one who finds this universal hitch to be a problem. I understand it is one piece of hardware used differently around the world, but that isn't really ideal. The first problem I have is this huge flange. It is difficult to get a hitch pin in there, and a locking pin is nearly impossible. I think I will try the Rhino one because they key goes on the end. I spend entirely too long battling this every time I try to hook up something different.
Even more strange is the 2in channel seems to be a finger trap. I have some hitched that won't even go into it. Maybe it is a matter of the tolerance for "2 in". More hitched, racks, or whatever just get stuck. I can wiggle them side to side and up and down, but they won't come out. Twice I have had to use a ratchet strap and a mallet. I've never seen anything like that before. One was for a bike rack and the other just a basic hitch.
I guess this is a three part question. Is anyone else seeing this finger trap problem? Is there some trick to working around this huge flange to get pins in there? And is anyone aware of someone coming out with an aftermarket US spec hitch that will make this go away?
I have the standard 2" CURT hitch from Autozone or Oreilly and it fits fine. My older hitch needed some "Grease" (ie i needed to sand the rust off) and it fit fine. For the pin, I attach on the left side, going straight up parallel to the hitch itself. Works fine.
I bought a hitch extender to clear the spare wheel. Both the extender and my 1Up bike rack fit the Grenadier fine.
How many bikes do you have on the rack?
I use paclock's trailer lock. I have a bunch of their locks keyed alike -i'm super happy with them. And i love that all my locks share the same key, i basically have all my locks for the car and the trailer keyed alike. fits perfectly (and the blue color works well with my shale blue gren).
I usually only carry one bike. I only attach the second rack 2-3 times per year.
Thank you. And the extender is also designed to carry 3 (e)-bikes because of the torque?
What solution did you come to for this one? I have the same silly question!
I might be off track here but if you're talking about the factory hitch receiver then the elongated holes underneath are for the safety shackles/chains.
I have a hitch extender for my bike rack on the Defender which has the same issue with the spare tire. However, for towing I wanted one that kept the default tow rating. So I just got a longer bar that is straight to keep the 7700 tow rating and the hitch weight rating. Just a basic Uhaul style.
Probably going to buy today so maybe I should bring my hitch.
For chains I know you can use a carabiner that is smaller with a high enough rating. I had this issue with my LR3 small holes for the chains.
This is not what I got but one example. They have 10,000 pounds as well
