The MY24 NA brochure says 91 octane recommended. 87 octane minimum.
In US translation, he usually runs 91 octane and 93 if the vehicle is designed for it.In petrol vehicles i usually run 95 as a minimum and 98 if the vehicle is designed to take it.
In diesel vehicles i usually run premium diesel not truck diesel.
Can only find higher than 91 AKI gas here at a very few stations, and then, it's "racing fuel". I know of one station that sells pure gas @ 100 octane. Mixed some into my E60 M5 once or twice and it really livened it up! I think I got it to 95 (US) octane with that fill-up. I had an aftermarket tune.In US translation, he usually runs 91 octane and 93 if the vehicle is designed for it.
For diesel vehicles, he uses diesel.
Typically all the gas stations in most locations comes thru the same pipeline is stored in the local tank farm and picked up by tanker trucks and hauled to each gas station regardless of the brand. Only the additives are different or not used.I've driven vehicles hundreds of thousands of miles primarily on Costco fuel, including BMWs. I guess I didn't care about my engines. There are a lot of old wives' tales out there based upon nebulous marketing, with few facts to back them up. More or different additives do not necessarily equal better or necessary for an engine.
In the US ethanol blended gas, typically 10%, is pretty much the standard. It‘s not as common to find non-ethanol gas. I happen to live by a station now that’s sells both but I don’t know if the lack of ethanol in the 87 adds benefits that offsets the higher 91 octane of the ethanol blended gas. Interestingly, the non-ethanol 87 sells for a premium grade price per/gal.I wouldn't put fuel with ethanol in it into any engine, unless the fuel lines and fittings have been designed for it.
This is true in New Jersey. Not a big deal for modern vehicles, but all my non-automotive small engines I run on Avgas - clean and pure.In the US ethanol blended gas, typically 10%, is pretty much the standard. It‘s not as common to find non-ethanol gas. I happen to live by a station now that’s sells both but I don’t know if the lack of ethanol in the 87 adds benefits that offsets the higher 91 octane of the ethanol blended gas. Interestingly, the non-ethanol 87 sells for a premium grade price per/gal.![]()
Supply and demand. Not many non-ethanol stations, so they can charge a premium. (Maybe the wholesaler does as well.) High demand for small engines (lawnmowers, etc.)I believe it's the government subsidies for ag-based fuels that makes ethanol cheaper than fossil fuels. Also, with diesel around here the higher percentage of biodiesel in the mix the cheaper the price. You're paying for it in taxes.
