Unused electrical connector (rear right)
Jean Mercier
GG#920
6:29 AM
Sint-Martens-Latem, Belgium
Have a rattling noise in the back of the car since some weeks. Therefore I dismounted my right rear trim this afternoon, to see if something behind it is loose. Had not done it before.
Anyone knows what this connector is for? (unused, 1.7 volts fluctuating when contact off, and 2.0 volts, fluctuating when motor running):
The only thing that was loose was the cable powering the Albright relay (for powering the NATO plug):
You can notice the loose clip. there is hole where you can plug it in (not visible, I did it by feeling)
But this wasn't the cause of the rattling.
I think it is the other (left) side panel, where I broke two clips some months ago while dismounting, but not sure yet.
Hi Jean. Firstly, thank you for the wealth of information you have contributed to this forum.
It looks like you have the towing option? On my vehicle most of the towbar wiring harness connects at the larger connector above. Pin 9 is supplied by a single 2.5mm green/purple 12v supply from the connector you have marked. I cannot recall if it is live 12v or ignition switched, probably the latter.
Haha, thanks for the explanation.
No, I don't have the towing option!
That is why you have much more wires coming out of the bigger connector.
That seems indeed to be the purpose of the single wire connector. But even with ignition on I had only some 2 Volt on it!
What is connected to the battery cables in the photos?
as @DaBull explained, and for those who are less "electricity minded", here how it works:
When motor runs, a tension is applied (most probably 12V, low current) to the black and green wire of the "Albright" relay. Therefore the switch inside the black box closes (red lines), and 12V is passed through from the red battery cable to the red/black NATO plug cable.
If I forgot something, please correct me.
Is that connector into the CANBUS circuit??
You'd better bought the Grenadier as a CKD-Kit.... :LOL:
AWo
Sounds more like "floating voltage" being induced in the cable, rather than a purposeful "here is a 2V supply". It's such a strange value ...
Is it a pull up or pull down voltage due to that cable being connected to a module or ECU at the other end?
Since you have a petrol version I was wondering if it was the controller for the Adblue system and the on screen monitoring of the Adblue warning level.
Ah, I see, this could indeed have been an explanation. But according to the other answers it is related to towing :-)
Bonjour à tous
Moteur éteint, j'ai mesuré la tension sur l'arrivée identifiée 12V sur la photo de l'installation sous le cache Arrière droit dans le coffre.
12,57 Volts - Moteur coupé
14,16 Volts - Moteur en fonctionnement.
En revanche, je n'ai pas de tension sur la prise OTAN (capuchon vert à l'arrière).
J'ai essayé avec PWR sur On et EXT4 sur On.
Toujours pas de tension sur la prise OTAN à l'arrière.
Est-ce quelequ'un sait ce qu'il faut faire pour que la prise OTAN soit alimentée ?
Merci de vos retours.
Bonjour à tous
En
To be honest, I didn’t check if there was tension on the NATO plug.
Hi. Sorry, I can only respond in English 🙏.
No power at the NATO socket is a known fault if you do not have the front winch option on your vehicle. This may be fixed in the current software update to version 1946. I'm not sure about that though.
While you're waiting for a fix from Ineos you have two choices to get power to the NATO Socket:
1. Move the large red cable from the right terminal of the relay (called an Albright solenoid) to the left terminal so both red cables are stacked onto the left terminal. This will bypass the Albright solenoid so the NATO socket is live all the time. There is no risk of draining your battery unless you leave a load plugged in for a long time and the engine is not running. Disconnect your battery or batteries before doing this because the left solenoid terminal is live as you have measured.
2. Follow these instructions to connect an ignition switched 12v signal to the Albright solenoid so it closes whenever the ignition is ON. This method uses the spare 'compressor' wires under the back seat to activate the solenoid by putting 12v onto the spade terminal to close the solenoid. This is the method I have used temporarily. Extend the yellow ignition switched wire and connect it to the spade terminal in place of the green wire. Leave the green wire unplugged.
