being used on level 4 presently to blow away the Grenadier blues (sick of waiting syndrome)Expecting a small report now, with copious photos, and a special section on it's uses around a Grenadier...
Letters inside == valves inside?Well used mine it to check the tyre pressure in the spare as there's not clearance to get my normal gauge in there - and bumped the pressure up to 49psi as per handbook recommendation. Worked a treat:
BFG lettering is outside from factory.Letters inside == valves inside?
Never thought about it. So the tires haven't been re-mounted on the rims to have the letters inside, but the rims just got turned? Is that possible?
I thought that only one side would fit properly for the bolts.![]()
Never thought about it. So the tires haven't been re-mounted on the rims for letters inside, but the rims just got turned? Is that possible?
Spare wheel is the keyword. Didn't notice that.Spare wheel is mounted "backwards"
