- Local time
- 3:35 AM
- Joined
- Sep 25, 2021
- Messages
- 392
Yes, I have to be ready to ‘unship’ my Midland antenna for entry into parking garages, car wash, etc.Looks like I need to be able to get in the garage, but look good.
Please post pictures of what your solution is for the gap. I would like to see what ends up working for this. ThanksTrying to test fit the Front Runner Nato Can holder, I can get great connection down at the airline track, now have to work on addressing the gap at drip rail, it was about 1/2 inch shorter and the base was drilled out to 3/8 of Inch , this would be great out of box solution out of the box.
View attachment 7858704View attachment 7858705View attachment 7858706
Thinking about some idea. I am sure I could 3D print a fix.Please post pictures of what your solution is for the gap. I would like to see what ends up working for this. Thanks
It's hard to tell from the angle but those top clamp gaps may actually be useful to be able to install a protective barrier between the Frontrunner mount and the painted drip rail. Perhaps a strip of HDPE or similar.
You can rotate ( it more like angle them in around foot for ward or backwards since it single bolt and and up and down,2 questions if you don’t mind…
Can you rotate the s2’s on the rack forward and back at all, or just up and down?
How did you mount the faceplate of the radio to the owl bracket? I love this idea for a HAM faceplate!
Hi angstrom, Liking the Leitner Rack. DaBullPicked some shovels or axe brackets from Builtright Industries for my shovel, Dewalt 32 inch D Handle shovel is from Home Depot, I had been using Dewalt planting shovel really like them. To attach the brakes to the rack you need the Leitner Bolt Kit-Track lock
Very much, it is great rack. I used some may racks over the year, it just very high quality .Hi angstrom, Liking the Leitner Rack. DaBull
I have the owl track and that radio. Which mount did you use to attach. Great idea.
Also where did you mount the base unit.I have the owl track and that radio. Which mount did you use to attach. Great idea.
it under the driver seat.Also where did you mount the base unit.
I used the back that is angled up that came with radio, you need to get two bolts and drill out plate for bolts, 1/4"-20 thread.I have the owl track and that radio. Which mount did you use to attach. Great idea.
