Transfer Box Lever
DCPU
1:40 PM
Has anyone noticed that the high low lever does not have a neutral position?
grenadierboy
12:40 AM
Armadale Australia
yeah. The old G wagens have High-Neutral-Low but i suspect that's because of the 40 year old design of the transfer case
bemax
2:40 PM
Presumably there is a neutral position between witch should not be used
bigleonski
11:40 PM
Brisbane QLD, Australia
Yes. Maybe I will ahve to start carrying my keys in my left hand pocket instead of my right.
Then I will have to get them out with my left hand and voila
I haven’t taken my keys out of my pocket near the 200 series for over 10 years. Auto sensing and Auto start is actually pretty handy and I’ll miss that. Actually having to use a key again will be weird, and until I’m used to it again, probably a pain in the ….
DaveB
11:40 PM
My wife has a mini and when she goes to the beach she puts the key in a lock box as she has for many years with many cars.
Until I showed her that provided the key is within 1.5-2 metres of the drivers seat you can open the door and start the car .
Happily drive forever with the key in the lock box.
Conversely in my car you need to physically put the key in the ignition and turn it
It is so annoying, time consuming and tiring to put my key in the ignition and turn it but I have learnt to live with it.
ECrider
1:40 PM
UK
ha. I turned off the keyless entry on the D4, I can just about manage to push the button and open the door.
thieves in these parts scan for your keys while in your house (if not in a faraday type blocker) gain access to your car in seconds and drive off! All the while your car thinks the keys are in it.
scrotes!
DaveB
11:40 PM
scrotes!
Insurance companies in Australia report that 70% of all car thefts are done using the vehicles own keys.
Second highest is when the thieves scan the keys through the closed door hanging on a hook or on a cupboard and then capture the code.
7:40 AM
DaveB
11:40 PM
After all the comments on changing from high to low and engaging these on the move in the old Defender I thought I would do some research
Some snips taken from the old Defender 90 manual and posted in 2005
It would appear lots of options are physically possible in the old Defender but not necessarily recommended
I noticed the Defender transfer lever has Neutral position between L & H so you are never going directly between the two.
It also mentions speed limits and depressing the clutch pedal.
Hard to do in the Grenadier
I am pretty sure I recall our Austrian friend changing from low to high while doing about 60kmh (estimated) in Budapest???
bigleonski
11:40 PM
Dave for me it’s never been a requirement to go from high to low or low to high on the move. In the numerous 4wds I’ve had that’s never been required and always been done static (or almost).
The previous argument has been the capacity to engage the centre diff lock (in high range) whilst driving. Every 4wd I’ve had has this capacity (Toyota up to around 100km/hr), whether via a stick or push button, and not to have that capability would be a major flaw.
DCPU
1:40 PM
High to low is difficult to achieve simply because of the gearing; but low to high is reasonable when towing, especially when you've stopped on an uphill and need to start off again.
