Trailer Wiring and Hitch Install - All aftermarket
Hi All, I installed Oscar's hitch receiver, looks great to me, comes complete with bolts and lock washers. Simple install, just take off the little cover plate and bolt it up. His wiring setup wasn't quite done yet, so I just went down to the local U-haul and had them do the wiring setup for me. $850, and that includes the Curt wireless brake controller. The install looks good-might be another option for those trying to get it sorted.
Interested in the Curt wireless brake controller. So you've used it and confirmed that it will activate electronic trailer brakes? Curious what you are/planning to tow?
Thanks in advance.
Thanks in advance.
Hello, I haven't towed anything yet, but this thing is in pretty widespread use, so I'm feeling ok about it working. It links to your phone, so you can pre-set profiles in it for different trailers. I have 2 things to tow, one camper that's a mere 1700lbs, and also a 7kgvw flatbed (maybe 5k actual max depending on what I've got on it). I'll set the gain quite high for that, but it'll be a few months until I actually use it. It apparently has an inertial mechanism of some sort that modulates the brakes based on deceleration. Quite a bit online about it, but I thought it would be a good first thing to try just because of the ease of installation.
Be a while before I can report back with any real world experience.
Good luck.
Good luck.
Many thanks for the reply. Will look into it more because it just seems like a no-brainer solution than the wiring work around everyone is having to do.
I originally installed a passive trailer wiring kit. It ended up throwing some codes and I have not really used it but it functioned regardless. I'm planning on swapping it this weekend for this unit that does not require wire splicing or scotch locks etc. Additionally it has its own power so it should be completely passive on the wiring side so it should not be able to throw codes on the lights etc. Hopefully it's the best solution for me.
I originally installed a passive trailer wiring kit. It ended up throwing some codes and I have not really used it but it functioned regardless. I'm planning on swapping it this weekend for this unit that does not require wire splicing or scotch locks etc. Additionally it has its own power so it should be completely passive on the wiring side so it should not be able to throw codes on the lights etc. Hopefully it's the best solution for me. View attachment 7888292
I tried this and it seems the unit wouldn’t accept the low voltage input from the wiring at the back of the truck. Ended up returning it.
Did you clip it to the pig tail wires that terminate at the trailer module plug? If so I would expect it wouldn't have worked. The sensors need to be on a wire with a load at the end.
I will test it out and see what I find though.
This is what I used, it’s powered from the Battery, or a relay, or a power source of your choice. Than it taps into the rear wiring. But the signal out to trailer is powered by the power source and not the vehicle side wiring. Built an adapter plate out of micarda, and installed two rivnuts in the frame mount to make installation form the outside easy.
