Man JAILED due to overloaded caravan!
In 2019, Stephen George Russell was found guilty of driving dangerously by towing a grossly overloaded caravan when a horror highway crash killed his wife and stepson in 2019.
I think you’re spot on.This is the difference between our cultures I suppose, individual rights over a common goal.
The community benefits from this. Does it make the community safer?
Yes, what have you lost? Not much, just an inconvenience of having to comply with the law.
Philosophically I think we all agree with you. However, that makes the assumption of proper equipment, safety protocol, and intelligence. Not everyone can be held to this level of responsibility (take the guy in the Jimmy towing the huge caravan).I prefer to tolerate a little more danger to enjoy a little more freedom.
Only problem is that some people's idea of freedom is very different to others.I think you’re spot on.
I, however, personally come down on the other side of the equation.
When in fact they are less so. But we won't go down that rabbit hole...Only problem is that some people's idea of freedom is very different to others.
Some countries tend to use the word "Freedom" very freely, as if they are the only country that has it.
So they regulate what size ball you can have on your hitch?European towing regulations are quite different from those in the US.
...and if you have two one must be 5-15mm lower than the other.So they regulate what size ball you can have on your hitch?
