Tie Down Rail
10:38 PM
Dandenong South
Hi all, I'm interested in receiving an image of bolt head fixing the tie down rial to the body so I can purchase the correct tool to remove and replace as I wish to insert a different fitting inside the rail.
Kind regards,
Gary Plant
Kind regards,
Gary Plant
Gary
L track
The L track in the rear cargo area of the car or on the exterior, or both? It sounds like the exterior.
The countersunk bolt heads holding in the L tracks leave the tracks free for standard size L track "nuts".
L track information here.
Bolt head
If you mean the type of bolt head used to secure the L track onto the exterior of the car, it is a Torx TX30 bolt head.
Toolkit
The most useful toolkit I have for the Grenadier/QM is the Wera WER05056490001 Tool-Check PLUS Bit Ratchet Kit (39 Pieces) - which has a Torx TX30 bit.
I see it is your first post. These links may be helpful:
PLACE TO START FOR NEW OWNERS
  1. Download and use the Rok Dr Guide here. Print out a copy and keep it in the car;
  2. Grenadier Accessories (huge selection) for you to buy here;
  3. Kanvas bags and products here;
  4. Information concerning Deutsch DTP plugs here;
  5. Learn more about the CTEK SMARTPASS 120S and 250SE here;
  6. Fuse and relay thread here;
  7. Suggested Grenadier or QM fuses spares kit here;
  8. Littelfuse FHZ busbars used in the Grenadier here. It also informs you where all the busbar cables go;
  9. Finding the aux power outlets in the footwells here;
  10. Table describing all the available wire ends here (more wire ends if you selected the high aux power option);
  11. Various recommended torque settings here;
  12. Tool kits for the Grenadier/QM discussed here;
  13. L track information here;
  14. Oil filter part numbers and third party filters here;
  15. INEOS Air filter parts numbers and cabin filter here;
  16. Filter for Diesel water separator here;
  17. Understanding the NATO plug on the Grenadier here;
  18. What do you use on bolts/screws to stop corrosion, galling and seizing here;
  19. Thread on useful tools for the Grenadier or QM here;
  20. Guide to terminal crimping here;
  21. Anderson plug pitfalls here;
  22. Outback driving tips here; and
  23. Cheap battery monitors here.
INSTALLATION (OR HOW TO) GUIDES
  1. SEAT COVERS: Canny Outdoors video fitting seat covers here;
  2. SPOT LIGHT REPLACEMENTS: Mounting Kit of Exezit Lights here and KC Hilites here;
  3. SIDE MIRRORS: Installing SUMA Performance side mirrors here;
  4. WORKLIGHTS: XHQ Work light here, with installation instructions here, STEDI Work light here and here;
  5. REAR ROOF SHELF: Canny Outdoors video installing KAON rear roof shelf here and a Travel Buddy oven fitted to a rear shelf here;
  6. ROCK SLIDERS (ABNTR4X4): Installation video for ABNTR4x4 Rock Sliders here, with suggested improvements for tougher environments here;
  7. ROO BAR: Installing the Roo Bar here;
  8. ROO BAR LED LIGHTBAR: Installing a 20 inch Lightforce Viper lightbar under the Roo Bar Hoop here;
  9. UHF (CB) RADIO: How to install a UHF (CB) Radio in an INEOS Grenadier without drilling any holes here;
  10. UNDER-BODY ARMOR (RIVAL): Installing Rival under-body armor here;
  11. UNDER-BODY ARMOR (CUSTOM OFFROAD) BASH PLATES: The installation thread is here;
  12. UNDER-BODY ARMOR (CUSTOM OFFROAD DIFF PROTECTORS): Installing the diff protectors and trailing arm protectors is here and the PDF here;
  13. UNDER-BODY ARMOR (ERO FLO FUEL FILTER GUARD): The installation thread is here and the PDF here;
  14. SIDE STEPS: Electric side steps installation guide here;
  15. INSTALLING AFTERMARKET SPEAKERS IN FRONT DOORS: instructions here, German language install here;
  16. INSTALLING BLACK SHEEP NUMBER PLATE HOLDER (US/AU models with OEM winches) here;
  17. INSTALLING REDARC TowPro Elite3: look here.
  18. B PILLAR (DISASSEMBLING): look here with detailed instructions here;
  19. INGEMAR’S GRENADIER HOW TO SERIES here and here (e.g winching, offroad modes, diffs, etc);
  20. INEOS FORUM resources here;
  21. INEOS Fitting Guides here, at least 9 guides from INEOS and Rhino Rack.
