- Local time
- 6:43 AM
- Joined
- Nov 14, 2021
- Messages
- 1,176
If Sir Jim is happy to have cold hands, he may not do a lot of ice-scraping in the dark, when its -20 Fahrenheit! Fifty degrees (F) below freezing is pretty cold.
I'm not really buying the "simplicity" argument. If a heated steering wheel fails, it has no impact on how the vehicle operates. You can drive your Grenadier for 30 more years after the heated steering wheel fails, and never repair it if that is what you choose. There are plenty of more complicated systems in the Grenadier that could have been omitted in favor of a simpler solution:
(1) A turbo-charged engine from BMW. While the B58 - overall - has a good reputation, there are much simpler engine designs available, with proven track records of reliability in truck and 4-wheel drive applications. A good naturally aspirated V8 will be more reliable, and easier to repair in remote parts of the world. A mechanic in Mongolia, Mali, or Madagascar will be able to work on a naturally aspirated V8; a turbo-charged engine from BMW - not so much.
(2) A computer-controlled automatic transmission: "Controlling the transmission is the integrated transmission control unit. The TCU works directly with ZF’s electronic valve body, also known as the Mechatronics. The valve body is the mechanical piece responsible for actuating shift changes and shift points. When combined with the integrated TCU, the electronic valve body could actuate the quickest shifts this side of a dual-clutch while reducing internal hydraulic drag during coasting for a significant bump in efficiency and economy" (Source: The Definitive Guide To The ZF 8-Speed Transmission). There are still excellent, robust, and simple manual transmissions in the market: Audi RS8, Dodge Viper, Dodge Charger with Hellcat engine, and many more.
(3) The manual lever for locking the center differential employs electronic actuation. Older versions were mechanical.
(4) There is a whole suite of features on the touch screen, including a feature that allows you to communicate directly with another Grenadier, and get navigation info from them. They could have just gone with a simple screen for the back-up camera (which is required by law in North America).
(5) There are heated seats. Are these LESS complicated than a heated steering wheel?
I'm going to stop here. My goal was not to rag on Ineos for their choices on the items I listed; rather, it was to point out that the "simplicity" argument for not including a heated steering wheel doesn't stand up to scrutiny.
I hope that other people feel as I do about a heated steering wheel and send Ineos a polite request on their Grenadier website. I'm tired of sticking my hands on the heater vent (once it has warmed up), trying to thaw frozen fingers before venturing out for winter adventures.
All the best!
All the best!
