- Local time
- 8:01 PM
- Joined
- Jul 27, 2022
- Messages
- 6,005
Excellent explanation ~ that makes sense now. It must be less of a hard bump stop than on old Defenders.I'm suggesting it's designed that way. When the springs are compressing /decompressing, bump stop plates are actually travelling through an arc. The rubber bump stop is touching the plate off centre for "normal" suspension travel because the arc is shallow.
At the extremes of articulation the bump stop plate travels upwards in an arc and moves closer "inwards" relative to the fixed position of the compressible rubber stop ... At the limit, the plate will have moved far enough "inwards" so that the centre of the plate is now compressing the rubber stop for maximum force path effect...
