I join in the compliments for the work
I honestly expected a more accurate general assembly.
In these conditions, if nothing is done, I don't think you would travel many km before having problems with damaged pipes or peeled wires... on a €80,000 vehicle, that's not acceptable.
then I would have expected a front axle with constant velocity joints in oil bath. land style.
these dry double u-joints cannot be greased. how will they resist tarnishing and rusting considering they will pick up a lot of mud?
How far can the steering end stop be changed before they suffer? on my land I had them adjusted to have a little more steering.
also the wheel bearings in this way will never receive a little oil.
All steering heads are also non-greasable.
I'm also dubious about the placement of the radiators. the central seems to me very low and very exposed to impacts compared to the old defender.
as well as the two lateral ones.
Is it possible then that the anterior bumper is made up only of plastic and that thin sheet inside that supports the side radiators?
