Sporadic Single Click (warning sound) - any ideas?
Simon Thompson
3:28 AM
Spokane, WA, USA
I recently took ownership of an INEOS Grenadier. I am experiencing sporadic and random single clicks (warning sound) and cannot determine the reason. I have the Over Speed warning on the FAV button so disable every time I start up. Plus the PDC and Input Sound are off. It is not the obvious lane departure without a turn signal activated as these primarily occur while dead straight ahead or turning left or right (with turn signal activated).
Anyone have any ideas on what to try next?
With thanks in advance,
Simon Thompson
Check settings/ vehicle functions/ speed warning, and make sure it's off. Setting it to 0 resolved my issue as it clicked each time I reached X MPH.
I had this happen this morning, first time on road I often travel. I just held in the mute button and after a restart of the car it stopped.
I have the same issue since a few days. It is NOT the speed warning, which double klicks four times and which we all now is a nuisance which needs to be solved by INEOS ASAP.
The issue which Simon describes is one single click, from time to time, although ADAS and overspeed are switched off. I think it may come when the vehicle does minimal shaking (potholes?) or in very slight turns (2 degrees roll). Perhaps the clicker gets voltage from a neighboring cable, or some software interacts unexpectedly.
I will be at the dealer in two weeks to get this checked, and it MUST be solved because it gets very annoying!!!
I get it when moving from one speed zone to another even if ADAS clicks are switched off.
There’s another toggle to eliminate that. Good thing is it remembers your choice.
Krabby is right.
Solved the single click issue (sort of…).
It stops when I deactivate “speed change info”. Apparently, the car thinks there is a new speed limit and hallucinates a bit, perhaps gets wrong info from the camera or from GPS about a speed limit. I switched it off, and fortunately it keeps it off.
Simon Thompson
It’s the speed change warning. It signals whenever it recognizes a road sign where limits go up or down. Disable it when you disable your speed limit warning and you will have no more annoying clicks.
Simon Thompson
There’s a drowsy driver setting in there too to turn off. Crazy that this resets every time.
