spare tire delete kit
S
stu1gpx
Guest
I am in search of a spare tire delete kit that will cover up and plug the holes left behind when you remove the spare tire.
Let me know if you know of a solution that is available.
Thank you
Thank you
Looks like a good place for a forum members badge to go, @Stu_Barnes!
I'll be the one to ask it.... Why move the spare from the super reinforced, easy to access rear door that is totally happy carrying a 35" (or potentially larger) tire
Perhaps the OP doesn't see a need for a spare wheel which might never be used other than for occasional "rotation" at the annual service to spread the wear.... :unsure: 🤷‍♂️
Thank you
I removed my spare tire because I think it looks much better without it. I stored the tire in the back of the vehicle. Upon inspection, I noticed the welds attaching the hub to the rim are already rusting. I suspect this may be true for all the wheels, so I'll need to inspect them right away.
Did you ever find a kit to cover the holes left by removing the spare tire? As a short-term solution, I'm considering 3D printing something to cover them. I'd need to use some type of foam-like material on the back of the printed parts to prevent vibration from damaging the paint. I'd much rather buy a solution if available.
Agree with your statement- did you ever discover a solution?
Maybe the ladder delete plugs will fit? What's the thread size/pitch? A nice torx head bolt and a stainless fender washer would work. Add a rubber fender washer underneath to prevent water ingress.
My local dealer has done this on some of the rides here in AZ. You might want to look up Arrowhead Ineos, I'm sure they can hook you up with a kit.
