Show us your mods.
scottyboy436
11:13 PM
scotland
I can't get my pixel 9 pro xl to charge with the quad lock charge head.
I logged a bug report with Google. I assume all works well with your phone?
I really like quadlock super solid mount, and easy to orient the phone sideways if you need to.
Yeah once I wired it up and tried it would charge for 3 seconds , so quad lock refunded my case(got to keep it) , returned the 12v head and got a normal head with the motorcycle 12v to usb .
Funny thing is my pixel 9 XL wouldn't work with the quaf lock but worked with other wireless chargers. Quad lock support said there investigating it but it's pointing towards the phone
ADVAW8S
Global Grenadier 0044
3:13 PM
Kirkland, WA, USA
I have a pro and I have noticed that you have to be spot on with the wireless charger for it to connect. Here is a post on pixel forum.
My new 9 Pro XL has odd behavior with wireless charging. I first noticed this with my Anker MagSafe charging puck and a Mous MagSafe Case.
It would show charging for a few seconds, then stop. Temperature of the device was very cool.
First test was to remove the case. This resulted in the same behavior so the case is not the issue.
Next test I tried a regular, non MagSafe Qi charger. I noticed getting the right spot was more difficult than with my Pixel 8, but I could get it to work randomly. But it would seems to randomly start, stop, and get really hot.
Next, I tried the MagSafe pick again by plugging it into the USB-C port of my Macbook Pro. Oddly enough, this works perfectly! With the case on as well, charges as expected with sufficient speed and minimal heat, as I would expect the Anker 20w wall charger to do.
So it seems there is clearly something odd with the amount of power being provided. It seems to be very finicky where the Pixel 8 was not.
scottyboy436
11:13 PM
scotland
Yeah I think it's just the phone that's the issue . The quad lock was rated for 3a max so it's quite alot. I'll just stick to the wired charging , see what the pixel 10 brings next year
parb
3:13 PM
Silicon Valley, CA, USA
i think it was my pixel as well. I logged a case with google mostly to get confirmation. I live close to the google campus and told them they could check out my devices live if they wanted to.
scottyboy436
11:13 PM
scotland
[/QUOTE/]
I wonder if there pixel stand works with the 9 , would be interesting to see , should go in by and see
ADVAW8S
3:13 PM
Kirkland, WA, USA
That looks pretty good , but already invested into quad lock at this point and have the wired charging working at the moment but I'll see further down the line
I have the peak case and charger. Just waiting on my QM. The case does not play nice outside peak econsystem
Shopkeep
10:13 AM
My Offspring gave me some Stedi lights for Xmas, including two rock lights that can be mounted on the Kaon side molle panels I have in the rear (the panels have mounting points & holes that are designed for the Stedi rock lights). I also have the Kaon rear roof shelf which blocks out much of the roof mounted light, making it a bit dark out back. Installed them this evening, after pulling out the existing light I fished the rock light cables out the roof light hole and spliced them into the roof light cable. Very happy with the result, the rock lights are very bright which suits me fine.
