Shovel Side Mount Using Utility Belt
Thanks to all the advice here, I have mounted a shovel onto the utility belt.
I used a pair of https://www.z1motorsports.com/misce...l-quickfist-riser-by-z1-off-road-p-44901.html
Attached to the utility belt using https://www.aliexpress.com/item/1005006954198737.html
I chose the M6 bolts, so I didn't have to drill out the risers.
The shovel I used was a https://www.roofracksgalore.com.au/spade-black-1065mm-handle-blue-grip
Next step is to apply some type of grip tape to the handle (where the QuickFists grab it) to prevent the shovel from rotating and touching the bodywork. 🙂
View attachment 7873501View attachment 7873502View attachment 7873503View attachment 7873504View attachment 7873505
Nice setup! What are the 2x vertical bars everything is mounted to called / made by? They look nice and light compared to the massive molle panels from Alu-cab and the like.
Thank you. 🙂
Universal side carrier from @Black Sheep.
Bulletproof side belt alternative if you have Leitner side mounts. Just drill 2 holes
Solid and goes anywhere
