Rok_Dr’s Exceedingly Unofficial Owner’s Manual Supplement
Hoping the following could be useful. It seems not to be present in V7-0a release.
E-CALL not working (red led).
Remove for 20" the fuse indicated below
Reconnect it.
Reconnect it.
Thanks @alvan. As we don’t have e call in Australia I’ve steered clear of adding it to the manual as I can’t independently check things.
As it’s a good tip I’ll work how to include in the next edition.
Cheers
Steve
My e-call hasn't been working properly for months. Only the red LED lights up. Today I tried "@alvan's" tip. Now the e-call is working as it should. When unlocking the door, both LEDs light up. After a short self-test, the red LED goes out and only the green one lights up. Thank's @alvan
Thanks @Greasemonkey. Always good to get second confirmation.
UPDATED 8 February 2025. (v7a). New Link Follows: Refer to post #154 in this thread for changes.
https://drive.google.com/file/d/1-av_-zdaQEi2klxUnMYMOg2hfUTy28Sl/view?usp=sharing
UPDATED 2 December 2024 (v6). Refer to post #137 in this thread for changes.
UPDATED 8 October 2024 (v5). Refer to post #102 in this thread for changes.
UPDATED 24 August 2024 (v4). Refer to post #83 in this thread for changes.
UPDATED 28 July 2024 (v3). Refer to post #64 in this thread for changes.
UPDATED 2 July 2024 (v2). Refer to post #62 in this thread for changes.
UPDATED 3 June 2024 (v1.1). Refer to post #48 in this thread for changes.
Since Christmas I’ve been slowly compiling an off-line document which I can print and put in my glove box that captures information missing from the owner’s manual and other useful bits and pieces.
I’ve now got it to a point where its ready to share with forum members. You can download the new PDF using the following link:
Use link at top of page now
The forum has been a great source of information so thank you all for your efforts. Posts I’ve drawn information from are referenced (if you need further info) and members acknowledged in the document.
I’ll update the link in this post and post an alert in the thread when I update the document. Any feedback, corrections or even additions are welcome. Happy for you to share provided you make acknowledgement to this thread.
If you print it out either use an A5 page and shrink to fit or an A4 booklet in adobe reader print settings..
May you find it useful.
Cheers
Steve
Want to add one potential change. The steering fluid is the Pentosin CHF 11s but Pentonsin now makes CHF 202 to replace it. It's 100% compatible, usually cheaper, and was actually designed to replace the CHF11s to combat steering pump noise.
Thanks for that.
Both seem to be interchangeable and the Penrite equivalent here in OZ meets both 11s and 202 standards. Will make a note/update in the next edition.
Cheers
Steve
