Removing door panels/ color of the speaker wires
Eric.S.
7:58 PM
Hello everyone;) Small question, has anyone already tried to dismantle the door panel or do you know what colours the cables from the speakers have? I would like to improve my sound system a little, I find the originals terrible... In the B column you would also have to get to the cables without dismantling the door panel? I just want to install a mini subwoofer under the driver's seat, the space should be enough;) If this question has already been asked, I apologise;)
Upvote 0
Too bad, does no one really have any idea what colours the cables have? ;(
Upvote 0
Not on my priority list for several reasons :eek:
  • I am almost deaf from my left ear :(
  • My partner says that I am deaf from both, but that's only when she speaks :devilish:
  • I love to listen to music, but the HIFI quality is therefore less important for me :)
Upvote 0
I always say to my wife that she has to let me know when she is going to say something I need to hear
Upvote 0
Oh, that doesn't sound good...;( Unfortunately, I don't dare to dismantle the door panel, because I can't stand it if another clip is missing and everything rattles. I looked at the cables that go into the door, but of course they do not comply with the ISO standard🤣
Upvote 0
Jean, at me 100% the same, left ear deaf and looks like the same wife….🤗😆
Upvote 0
I'm not sure if any one has actually replaced the speakers at this point; I would suggest spending 5-10 minutes to pop each of the door panels off and perform a polarity test directly at the speakers. The clips that hold the door panel on are fairly universal, thus if you break one or a few, finding a generic replacement should be only an Amazon order away.
Upvote 0
Problem solved😅 Thank you @Jean Mercier for your preparatory work with the cables from the electricity, that made things easier;)
Upvote 1
Did you get to the head unit? Was there a port for a sub? Any other ports?
Based on the photos I'm assuming he grabbed speaker connections for the rear door from the B-pillar
Upvote 0
Rear dashcam fitted today. Technician showed me what he said was impressive build structure behind the rear door trim. Much stronger than LR
Where was it fitted on the exterior? I heard the factory one is not centered and it can be slightly difficult to use. Thanks.
Upvote 0
Apologies about digging up this thread again, but has anyone actually taken the door panels off yet? Looking to replace the speakers and would like to have a look before ordering anything.
For the front driver side I've found 3 bolts so far - 1 inside the interior door handle, one underneath and one the edge. Can't seem to see any more but its not lifting off that easily and am a bit wary or ripping anything out accidentally on a car that's been in my possession for less than 24 hours....
Upvote 0
