- Local time
- 3:28 PM
- Joined
- Aug 24, 2022
- Messages
- 2,450
Actually, just realised that I have ordered the fold down table, but that will be a pain with the fridge on the right, so will probably put the fridge on the left, which will be more convenient for power, but then may block access to jack etc. Maybe will put jack in rear wheel carrier lockable storage and put an inverter in that space.Helpful to read, everybody’s different ideas on this. I like the idea of drawers in principal, but in reality, they are quite a lot of weight and take up a lot of space, they also dictate the shape of the space to quite a large extent. If the primary use of the vehicle is camping and touring, probably not so much of an issue because everything will have its place and be in its place. But for me it will be very mixed use. I want to be able to pick up stuff from the hardware in it. I want to be able to camp and tour in it and I want to be able to go to holiday house with four people in it. For me, I find the most flexible combination is a few stackable milk crates for breakables and random hard gear, and then soft bags for as much as possible. But the problem is I also like to have a fridge in there and with that combination it’s very difficult to access the fridge on the road if you need to particularly if you’ve got stuff stacked on top of the fridge. Also not good for fridge ventilation. This will be particularly acute in the Grenadier as the space is up-and-down not so much depth. so to make the best use of the space. You will want to have the fridge on top of a drawer or to stack stuff on top of the fridge. The simplest solution to all of this that I can think of is a fridge slide in a simple box, so that the fridge can be slid out to access it but stuff can be safely stored on top of it without having to unstack it. The next question is which side, the obvious place is the right hand side because there is no jack behind that panel and you can open the large door and slide the fridge in and out and keep the smaller door closed to access the ladder to the roof. But oddly, despite all of the other electrical stuff that seems to only be a power outlet on the left-hand side, that’s kind of easy to fix I guess but still it doesn’t seem to make any sense. And yes I would like to be able to remove it easily if I can.
