Americas Remote starter
rbarsk
12:26 AM
USA
Does anyone know of a remote starter that would work on the Grenadier. Don’t think will fit in garage so will be cold in winter
If you're looking for a plug & play remote starter, nothing exists at this time. I'm sure some enterprising individual could get a Compustar generic remote starter wired up, but shy of that, it's going to be a bit chilly for the first few minutes
That’s what I thought also. I dont think it’s available
Remote start is one of those necessay luxury items at the same level as heated and cooled seats!
Anyone got an update for a remote start solution?
If you know of an older vehicle that has remote start and requires that the brake pedal be pressed for ignition to work, then whatever was needed for remote start to work there could be applied to the Grenadier.
With ineos using inductance sensor for brakes I do not see that being the case. For the Grenadier I think someone will have to hack the CAN bus.
For cold climates I would suggest a small
Diesel heater setup with remote start. Won't get you 100% the same effect but close enough maybe.
