Hey all. I’m installing the wolf box and when I was removing the rear view mirror the mount came off. Any idea how to put it back on? I have not had any luck.
For reference the windscreen end is a twist-off fitting. Turn the arm approximately 40 degrees anticlockwise and it will come away from the windscreen. Line it up and twist clockwise to refit. It's tight. Have some choice words ready.
Thanks Tom. I saw that but the 2nd pic is the same three-claw euro mount as ROW vehicles so once all the ADAS shi stuff is out of the way the metal arm should still twist off the stud on the windscreen. Is this not the case?
Edit. Had another look at the pic with my glasses on. The ADAS arm has the same claws plus those four short studs so no twisting for you. Carry on!
This is the end of the ROW non-ADAS arm, and the windscreen stud. Very similar but somehow different.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
