Rear bumper removal
Zartoon
10:05 PM
Los Angeles, CA, USA
Greetings all
Has anyone taken off the rear bumper. Are there diagrams of what it all looks like and procedure to take off and install? Is it one piece or 3 piece?
Specifically, need to remote rear left side bumper. If there are pictures, can someone point me to it?
Thank you
Steveo
Global Grenadier #1009
5:05 PM
Dandenong Ranges, Victoria, Australia
Greetings all
Thank you
Hi @Zartoon did you get any answers to your post?
I want to remove the rear bumper so that I can fit the valves for some suspension airbags
Cheers,
Steve
andremacd
8:05 AM
South Africa
Hello gents
I have also been wanting to take a closer look at the rear bumper so decided to remove the plastic covers from the right rear side. Quite straightforward, but as with most things Ineos, you will need a wide range of torx wrenches..
Start by removing the cap piece (below the Ineos sign) - 2 (T40 iirc) bolts from below. Now the plastic cap comes off by tilting upwards.
Underneath is a thin metal bracket - remove the 2 T30 screws from above. The base of this piece is also held in place by the T40 screws that you have already removed above. Metal bracket comes off.
The corner bumper is now removed: Two T45 screws adjacent to the pieces already removed. Five T40 screws to remove the mudflap. Two 13mm bolts from the undersurface. Now the fun part - two more 13mm bolts located inside the corner piece that can only be accessed by wedging your arm in from the wheel well. Disconnect the PDC and the piece is off.
Hope this helps.
Cheers
Andre
Logsplitter
6:05 AM
Hello gents
Hope this helps.
Cheers
Andre
Where did you get the auxiliary fuel tank made ? And is your Grenadier petrol or diesel.
Thanks
andremacd
8:05 AM
South Africa
Thanks
Hi Logsplitter…sharp eye!
Diesel.
Aux tank is made by highlander offroad, an under the radar top-notch engineer/apple farmer in Elgin, South Africa. 77 litre. Over engineered and built. Perfect for the grenadier.
Logsplitter
6:05 AM
Diesel.
When removing the rear silencer did you just straight pipe it or put a small silencer in the system.
hoohoohama
1:05 AM
New York
Has anyone ordered parts (for example, a rear corner bumper) from Ineos dealership? wondering how long the process takes these days.
hoohoohama
1:05 AM
New York
I recently ordered a rear corner bumper from the nearest dealer, surprisingly it only took about one week (shipping from Belgium) and cost $534
hoohoohama
1:05 AM
New York
Hello gents
Hope this helps.
Cheers
Andre
How did you disconnect the parking sensor? Do you need to pop it out first?
