- Local time
- 6:51 PM
- Joined
- Jul 27, 2022
- Messages
- 6,005
It does seem odd that where the Grenadier has gone down engineering routes to address so many other shortfalls, it has followed others with regard to a RAI and not a true snorkel.What the hell use is a “raised intake” if it isn’t a snorkel like a safari / airtrec etc?
By snorkel I mean apart from the big hole in the top, it is sealed all the way to the airbox. Although I think there is a drain hole in them somewhere that allows for bits of rainwater or whatever that inadvertently get in to clear somewhere.
If that is indeed the case ( I was promised a reply from customer service but never got one) then it’s a delete from me and waste of $1k or whatever the price is. Then I trust Safari will come to the party.
It's this joint in the inner wing that could have been designed as watertight that seems to be the 1st issue:
But you can see that any extraneous water drawn into the RAI is to a degree going to fall to the "sump" area at the bottom of the intake, whilst the air is drawn upwards and along the ducting.
