Raised Air Intake Precleaner.
Andrew Kilby
10:24 PM
Sunshine Coast - Australia
Raised Air Intake Precleaner - just wondering if anyone has the precleaner. Is it easy to remove and can it stay off until needed for remote travel i.e. Do you get the normal top to the raised air intake?
My grenadier is 13 months old done 60000km and have had the top spin fitted all the time. Last week noticed that it was lopsided all of a sudden and found a split along the seam of the raised intake section the top spin is fitted to. Have cable tied it closed and silastic along the seam and will drop into a dealer soon regarding a warranty claim.
Any chance you have a picture you could share?
Upvote 0
Sounds like a reinforcing band might be in order.
Upvote 0
Yesterday i had to take my grenadier to get the front & rear pinion flange seals replaced. Have ordered ARB diff breathers which according to one American expert is the only fix to stop it happening again.
So while i was there i showed them the snorkel issue. Was advised when i picked it up that the raised air intake was not a warranty issue as i had hit something. I’m now getting further information together to counter this claim. In the meantime i wont hesitate pointing out the problem to the many people that enquire regarding the vehicle every time i pull up somewhere.
Will keep you informed.
Upvote 0
Unfortunate. Talking down the brand might make you feel better but it won't help to get a resolution. But I understand your frustration.
It would be interesting to know if your dealer doesn't want to support a warranty claim for the RAI, or if they have raised a claim and IA rejected it. My experience is that where there is reasonable doubt, IA after-sales tend to find in favour of the owner to preserve the relationship. I'm talking about the Australian team only.
From your pic it looks like the hose clamp is installed too low. The band is sitting on top of the bottom ridge. If that's how it was originally installed it may be enough to create a local pressure point over the seam and initiate a crack at the end of the tube (the weakest point of the seam). Or, it might just be the way the clamp was refitted after the temporary repair 🤷‍♂️
I hope this gets sorted for you.
Upvote 0
I have complained a number of times re the raised air intake with pre cleaner. There has been no response other than a ‘re-fit’ of the existing setup, each time it comes apart. IMO, the unit is too heavy for the flimsy plastic the intake tube is constructed of. Just using it in a suburban situation on good sealed roads, movement of the pre cleaner causes the tubing to move and flex and part where it enters the front RH gaurd. There is no way it would survive a five minute drive on severe corrugations.
I know there is at least one after market (ridiculously expensive) sealed intake system available which appears much stronger, but I simply can’t use mine outside suburbia the way it is until there is a fix.
  • 9C8D96C4-135B-4F12-9FFC-CFFEC4D43408.mov
    2.2 MB
Upvote 0
Have you viewed “Raised air intake: what type of plastic?” thread on this forum?
Upvote 0
yep. same here. pinion seals have blown, likely due to design fault with OEM one way valves. Will fit the ARB kit when got it back hopefully next week. though also now have permanent off-road error so might take a while to diagnose. Would recommend a diff breather kit install to all regardless of regular driving conditions.
Upvote 0
You can get a smaller Donaldson top that puts less strain on the intake. Check out their webste
Upvote 0
Yes, I am well aware of that, but their specs are not as good…. But my main beef is that this setup is specified by Ineos and therefore should “be fit for purpose”‼️….. but it isn’t.
Upvote 0
I’m not sure how far the claim went but it was decided very quickly that i had hit something. There is no damage so I’m interested who decided that i hit something. I fixed the lower portion where it goes into the body with Siko flex.
I’m asked about the car constantly and always respond positively because i really enjoy it apart from little issues like this.
Anyway getting more photos together and see where it ends up.
Upvote 0
Even without the "heavy" pre-cleaner, the standard raised air intake will still fail! I have never had any hits or physical contact, and it has separated from the vehicle body. This is after 30,000km and occurred on the Hume Highway between Canberra and Sydney. Maybe speeds of 110km/hr are exceeding the design limit... The plastic hooks that fit into the vehicle bodywork have broken off. Even though the A pillar and bottom mounts are secure, there is still enough flex in the RAI body the separate from the vehicle.
Upvote 0
