Sort of - it’s in the centre console where it’s largely useless.Is there a cigar lighting thing up front to plug in the GPS?
Ah cigar lighters...the stuff of old Rovers and Jags!Is there a cigar lighting thing up front to plug in the GPS?
...the Puff of old Rovers and Jags!Ah cigar lighters...the stuff of old Rovers and Jags!
The former , uphill as well!...the Puff of old Rovers and Jags!
As long as you can quickly delete the "I made a very bad decision offroad" clip, one that will void insuranceI would think in the age of web cams that more vehicles would have considered thier installation.
Don’t think so. Closest is centre boxIs there a cigar lighting thing up front to plug in the GPS?
No heated seats?!!!!! Heathen.Assuming the console switch segments are actually separate and individually fastened in place, AND, as someone else has already noted, the heated seats are not fitted, then their respective fascia plates are "begging" to be repurposed! Hopefully IA deliver on their promise of open access to wiring diagrams
Not necessary... SE Queensland near the coast is 'sub-tropical'.... Most of the year it's between 20 and 30 deg C +/- 10deg C for the extremes in summer and winter.No heated seats?!!!!! Heathen.
I have something similar based on a cheap first aid cabinet from Bunnings ("Big Box" hardware store chain in Australia) .. I built it for the Santa Fe diesel ...connected to a 100AH LiFePO4 deep cell. The red Anderson plug supplies (smart) alternator power, the yellow is for solar panel input. The blue Anderson plug on top is for Li battery connection (different colour Anderson plugs are not inter-compatible). Controlled by Victron BMV712 smart meter with shunt. Projecta 25Amp Lithium DC-DC charger with solar input. Connects to a smart charger-compatible Anderson plug in cargo section of the SantaFe. I use it for CB UHF, a Bushman car fridge etc on long tripsWell if I decide this unit doesn't keep doing a fine job I'll work out something else![]()
Thanks, Good ideaPeople are going to want to mount a range of devices on the dash at various times: dashcams, phones, tablets with off-road navigation, head up displays etc. and there are no USB power outlets on the binnacle, the closest ones are in the centre cubby box. However there is power to a couple of places in the footwells, I think one each side standard and an additional one in the passenger footwell with electrical preparation and high load panel. So thinking about ways to solve that in a neat but convenient and interchangeable way. My mind is going to mounting something like this behind the touchscreen and wiring to one of those points behind the dash, but wondering what other ideas people have?
I can’t recall where, but someone posted that the stuff on that control panel is not backlit. Has anyone seen any nighttime/dark interior photos?Assuming the console switch segments are actually separate and individually fastened in place, AND, as someone else has already noted, the heated seats are not fitted, then their respective fascia plates are "begging" to be repurposed! Hopefully IA deliver on their promise of open access to wiring diagrams
One of the reviews I saw mentioned it’s lit by ambient light though it didn’t mention the source. (possibly from overhead switch panel)I can’t recall where, but someone posted that the stuff on that control panel is not backlit. Has anyone seen any nighttime/dark interior photos?
I haven’t seen any extra display (for example within the knob) so it’s presumably on the main displayAnyone know where the climate temp is displayed?
Thanks. I must have missed that along the way. The symbols are plenty visible, so again, nothing to fret over.
