- Local time
- 9:31 PM
- Joined
- Oct 11, 2021
- Messages
- 2,101
- Reaction score
- 3,032
- Location
- Kirkland, WA, USA
I've only got about 1,000 miles on them so far but I'm really happy with them.@Boise looking forward to your feedback. I'm thinking the same tires for the QM.
Hi Boise, Looks nice, what size? DaBullCouldn’t be happier with the Mickey Thompson 255/85R17s!
View attachment 7858533View attachment 7858534View attachment 7858535
Have you placed your QM order yet?
They work out to be 35 by 10Hi Boise, Looks nice, what size? DaBull
They are 255/85R17s. They physically measure 34.5" x 9"Hi Boise, Looks nice, what size? DaBull
They look very good, have you had to raise the car or do they fit with the original springs, if they are with the original springs have you checked if they rub in any situation, on the other hand have you had to approve the tires or do you not have them there problems with that, here in Spain you cannot exceed 3% of the diameter of the original wheel, if it exceeds it, a technical reform project must be carried out. Greetings PacoThey are 255/85R17s. They physically measure 34.5" x 9"
Where do you get this 9"? If one inch is 25,4 mm 255 mm should be quite near of 10"They are 255/85R17s. They physically measure 34.5" x 9"
Did you need a lift to fit those ?Couldn’t be happier with the Mickey Thompson 255/85R17s!
Yes. They definitely would have rubbed without it.Did you need a lift to fit those ?
Technically, if they fit with the Eibach springs at full compression, then they should fit stock at full compression as the bump stops and shocks are not altered with just the Eibach setup; sure static height is higher, but at full stuff it should be at the same positionYes. They definitely would have rubbed without it.
Agreed. Assuming that these lifted coils will compress enough to even reach the bump stops .Technically, if they fit with the Eibach springs at full compression, then they should fit stock at full compression as the bump stops and shocks are not altered with just the Eibach setup; sure static height is higher, but at full stuff it should be at the same position
Only 1% off? Should be 5+% off, so is the stock speedo/odo off from stock assuming owners will upgrade to taller tires? Bigger question is there any noticeable power loss with larger diameter?Installed the 255/85s with no lift. Just driving on road there was no rubbing. Speedo is only off by 1mph. Installing the lift springs now.
Have you had any issues with the tires now that you e had them a while? Lack of power? Braking issues? Gearing? I have my eye on the same size your running.Switched to Wildpeak A/T4W in 255/80/R17 from the factory BFG KO2s this week. So far so good.
Road manners... Improved. Aired up the same as KO2s, the Wildpeaks feel less harsh on poor pavement and easier turning at low speeds. Less noise up to highway speeds, then about the same, just different. I expect good rain and wet snow performance and I'll find out soon.
Dirt manners... Just one long test day so far, but barely airing down (to 31 PSI), they were fantastic in dry, sandy, rocky climbs. Rocky and wet, I expect about the same. And maybe worse in mud, but I have to choose my battles...
