Good question - I think it was discussed in another thread, but the outcome was that it would be beside a curtain airbag, but should be OK. But that was forum conjecture and nothing official from IA.Will it effect the airbag operation?
Would this work? They use them in Jeeps.In terms of RHD, I don't need one to get into the drivers seat, I've always used the steering wheel. UNLESS getting in is tight (door not all the way open for example), then the pillar grab handle is very handy. The one up top will do the job, just not as well.
A grab handle on the pillar for the passengers is however very much generally required on a vehicle this tall, and luckily it's supplied in the RHD.
I found getting into the back seats a bit of a PITA without grab handles though, and this is where I reckon getting them retrofitted would be worth it if you had people getting in and out of the back all the time..
Yes, you can use the door, or the top handles, or the body frame, or the seat or the roof rails or whatever at a pinch, but for the extra $30 it would have cost to install handles in the rear to give a much better entry, it would have been worth it.
I think it may obstruct the curtain airbag unless it folds completely flat or recessed.In terms of RHD, I don't need one to get into the drivers seat, I've always used the steering wheel. UNLESS getting in is tight (door not all the way open for example), then the pillar grab handle is very handy. The one up top will do the job, just not as well.
That looks aright actually - do you reckon it comes in a different colour??Might be cheaper to buy some extra cadaver pieces and attach a hand to the dashboard. Just tossing out ideas to help....
I presume for LHD vehicles there is a passenger handle in exactly the spot we're discussing for RHD? And there's a passenger handle on the LH A-pillar in RHD vehicles. Airbags in both LHD and RHD.Will it effect the airbag operation?
That's what I meant: If you sit in the passenger seat, you have the exact view as the driver had with the handle on his side.I suppose i should have phased it better as a question! ‘does the handle..’
i was thinking more about design regulations being very picky about possible obstruction. Years ago we were not allowed anything on windscreens at all for that reason; now people stick their phones on giant bracket right in view, to manage uber or whatever other distrations… seems to have changed one way or another. Anyway, you have a car, do you think it would be noticeable during turns on the drivers side?
Driver’s side handle probably omitted because it partially encroaches on the corner view out the windscreen. I still think the addition of this extra handle on the driver’s side may compromise roadworthiness in some jurisdictions.I presume for LHD vehicles there is a passenger handle in exactly the spot we're discussing for RHD? And there's a passenger handle on the LH A-pillar in RHD vehicles. Airbags in both LHD and RHD.
If these suppositions are both true then it seems the lack of a driver's side handle in either configuration is either a cost saving.... or there is a safety concern which is not readily apparent to us mere mortals.![]()
or just jump in or have something like this ....Yes, you can use the door, or the top handles, or the body frame, or the seat or the roof rails or whatever at a pinch
I still think it’s a cost issue. I have quite similar handles in my VW T6 which makes me think that it cannot be a compliance thing.Driver’s side handle probably omitted because it partially encroaches on the corner view out the windscreen. I still think the addition of this extra handle on the driver’s side may compromise roadworthiness in some jurisdictions.
I posted a photo in another thread showing this.
I assume with all the parts our there - you can get anything you want!That looks aright actually - do you reckon it comes in a different colour??
As the airbags are universal there should be no affect on the deployment of the airbag operation.Will it effect the airbag operation?
They want them to last for 30 years , not 10Will never understand why Ineos didn't just put one in on a high vehicle like this, and why are they so bulky!? The Ranger has them on both sides and more slimline.
I'm sure someone posted photos of the two trim panels removed and the airbags were visible and looked different (different colours?) for each side?As the airbags are universal there should be no affect on the deployment of the airbag operation.
