Message sent.Would you mind listing the tools you carry to replace CV’s. I would really appreciate it. I already have replacement CV
I have the same springs and King kit. Around town the truck rides great and I have the dials turned to the most form, which is all clicks to the Right. However, I still have a ton of body roll and unstable feeling at highway speeds and I have to back off the accelerator on winding highway. Feels like I could slide right off the highway or worse. Leeroy, do you get this also?I got my lift and the King shocks from Owl, and they did the install (in Arizona). I've had no problems = at 13,300 miles now, about 10,000 of those miles were with the lift and 35's - I've only had the Kings for about 3,000 miles. I highly recommend them, they dramatically improved the ride.
That is interesting, I had OWL install mine in AZ last week and I took a long road trip and offroad adventure and found no real issues. They set me at 7 clicks but I moved it to 4 to get it more stiff. After I did that it removed my body role and effect by wind on my road tip. I would assume setting to max stiff would even of benefited that much more. Sounds like you are having the opposite then my findings. How loaded was the rig when you feel that? I was running with about 500lbs plus two passengers.I have the same springs and King kit. Around town the truck rides great and I have the dials turned to the most form, which is all clicks to the Right. However, I still have a ton of body roll and unstable feeling at highway speeds and I have to back off the accelerator on winding highway. Feels like I could slide right off the highway or worse. Leeroy, do you get this also?
Thanks,
Joe
I don't have that issue and I drive faster than I should. It could be due to a lot of possible causes, like alignment/caster angle or steering damper. If possible, try driving another Grenadier and see if you feel the same way. I'm used to wobbly lifted SUV's so maybe I just don't notice it anymore after all of these years? But I never feel like I'm going to fall off the mountain.I have the same springs and King kit. Around town the truck rides great and I have the dials turned to the most form, which is all clicks to the Right. However, I still have a ton of body roll and unstable feeling at highway speeds and I have to back off the accelerator on winding highway. Feels like I could slide right off the highway or worse. Leeroy, do you get this also?
Thanks,
Joe
Thanks. I'm going to play with the shock settings to see if that helps. Would the new items from Metalcloak improve stability? https://metalcloak.com/ineos-grenadier.htmlThat is interesting, I had OWL install mine in AZ last week and I took a long road trip and offroad adventure and found no real issues. They set me at 7 clicks but I moved it to 4 to get it more stiff. After I did that it removed my body role and effect by wind on my road tip. I would assume setting to max stiff would even of benefited that much more. Sounds like you are having the opposite then my findings. How loaded was the rig when you feel that? I was running with about 500lbs plus two passengers.
I really don't think so, however they would seem to give more adjustability and maybe strength on the replaced components.Thanks. I'm going to play with the shock settings to see if that helps. Would the new items from Metalcloak improve stability? https://metalcloak.com/ineos-grenadier.html
I've ordered the new Eibach front/rear swaybars. I'll report back once these are installed.I really don't think so, however they would seem to give more adjustability and maybe strength on the replaced components.
If they are coming out with thicker sway bars I wonder if this means a lowering kit will be next? Given that thicker sway bars are the opposite of what you would want in any off road use caseI've ordered the new Eibach front/rear swaybars. I'll report back once these are installed.
INEOS GRENADIER FRONT/REAR SWAY BAR KIT
Eibach engineers, manufactures, and sells the highest quality performance aftermarket suspension products in the world.www.eibach.com
They are also silver!!! lolIf they are coming out with thicker sway bars I wonder if this means a lowering kit will be next? Given that thicker sway bars are the opposite of what you would want in any off road use case
