Overhead Switch Safeguard
chrsbe
10:10 AM
Sternwartestraße, Wien, Österreich
...working on a simple click on safeguard for the overhead switches. Just to make sure that Krampus does not jump out of his box in front of officials (or wifes).
Wow, Chris, the prototype looks very promising!!!
Thanks for your patience, here is the 3d print file for the overhead switch guard. In the movie, you see how it works and how satisfying it clicks when opened and closed.
The switchguard consists of two parts designed to be 3d printed. Use two M2 by 10mm screws to hold them together.
The best print orientation is seen in the image. I recommend using PET (PETG, PETGHF) but it will also work in PLA as print material. It is designed so you don't need print support.
Assembly is easy.
1) Start by clipping the larger part on the U-shaped metal rod.
2) Leave the clip in the open position to insert the smaller part.
3) Fix it with M2x10mm screws.
Thanks @chrsbe for sharing the file!!! Which screws do you recommend?
I hope that someone in the U.S. might obtain a proper license to produce this design and then offer units for sale at a fair price.
I will also protect the PWR switch that potentially could drain my battery overnight. The switchguard will give me a second layer of security here.
In keeping with this same theme, has anyone used a meter to check for parasitic draw with the PWR button on?
Will this prevent the switches (circuit breakers) from tripping in an overload situation ? Could potentially hold on a faulty circuit. I know when I was setting up my winch I managed to trip the circuit breaker.
To the best of my knowledge, they are purely switches and the circuits are fused elsewhere, so it would not harm anything if they were held in whatever position. Someone please correct me if I am wrong.
Thank you very much for this! I had a couple printed. They fit in such a way that the M2 bolts are for extra security, but don't seem to be needed.
