in what one?I have also noticed there is vibration through the transmission at about 1900rpm.
bloody hell that’s concerning
@MrJAT post above. Transmission warning light and vibration through the transmission at 1900rpm.@jean
in what one?
Vibrations tend to increase, not to decrease. Vibrations are/were also one of the issues which needed to be addressed by IA during the whole process.have also noticed there is vibration through the transmission at about 1900rpm. Has anyone else experienced this and does it ease off with more miles on the clock? Hoping once it is run in it will reduce a bit.
Deisel or Petrol?@MrJAT post above. Transmission warning light and vibration through the transmission at 1900rpm.
sorry, mis-understood, thought you had experienced same. phew@MrJAT post above. Transmission warning light and vibration through the transmission at 1900rpm.
Hopefully @MrJAT can confirm.Deisel or Petrol?
I am not concerned about the warning light. Apparently it tends to come on when you turn the ignition on too quickly without letting the vehicle go through its sequence of checks. So pause between turning the ignition to position one and turning it over. The vibration is not that bad, just expected it to be smoother given everyones talk of how smooth and quiet it is.@MrJAT post above. Transmission warning light and vibration through the transmission at 1900rpm.
DieselHopefully @MrJAT can confirm.
It is worse than you realise. In Australia (a metric country) we refuel in litres, many aircraft still measure it in pounds (the fuel gauge) then we convert it to kilograms. Speed/distance in knots, but measure visibility in metres. Runway distance also metres, but, basic charts are in feet. Altitude always in feet, except mountain height is measured in metres. Plus altitude is actually different to height, altitude is a pressure measurement defined by the local atmospheric pressure, however that is only below 10,000 ft. A radar altimeter will give actual height above the ground. Thankfully most aircraft above 5,700 kg are fitted with one.Why, we like Gallons and British Gallons, not the smaller American variety. Bloody Europeans at it again!
Fly aircraft, and you refuel in Ibs (sometimes KGs), fly in feet and travel in Knots. Work that one out.....
Sounds like a biker talking!Is the vibration in the hands or the cuffs of your pants...hands usually mean front end and cuffs back end...wheel balances hopefully.
I know, I was an FE on the TriStar and it was gauged in KG's but the UK Fastjets were in Ibs. At the end of the air to air refuel I had to give them their fuel in Ibs. Quick 2.2 x calculation. Once had a Jetplan (plog) in IBS that should have been in KG's (nearly caught us out).It is worse than you realise. In Australia (a metric country) we refuel in litres, many aircraft still measure it in pounds (the fuel gauge) then we convert it to kilograms. Speed/distance in knots, but measure visibility in metres. Runway distance also metres, but, basic charts are in feet. Altitude always in feet, except mountain height is measured in metres. Plus altitude is actually different to height, altitude is a pressure measurement defined by the local atmospheric pressure, however that is only below 10,000 ft. A radar altimeter will give actual height above the ground. Thankfully most aircraft above 5,700 kg are fitted with one.
It is actually amazing what you can adapt to. Yet converting mpg to l/100kms still does my head in. Prob because it is inverted.I know, I was an FE on the TriStar and when gauged in KG's but the UK Fastjets were in Ibs. At the end of the air to air refuel I had to give them their fuel in Ibs. Quick 2.2 x calculation. Once had a Jetplan (plog) in Its that should have been in KG's (nearly caught us out).
As you flying in feet, but when working for Cathay, over China in metres. Winds in metres per seconds in China, everywhere else in knots. Temps in Celsius and Fahrenheit. Visibility I'm Metres and Miles. Had to have your wits about you flying in 747's worldwide.
Is it velocity related or engine revs related?I have also noticed there is vibration through the transmission at about 1900rpm.
No that was @MrJAT post as above. He has his car.Do you have your car???? Or was that on a drive day?
It is engine revs related and not velocity. You can feel it through the accelerator pedal.Is it velocity related or engine revs related?
i.e: Does it always occur at around 1900 rpm regardless of gear and velocity?
