It's perfect just the way it is.Yes it's about as aerodynamic as the factory it was built in.
But if they improved the aerodynamic properties it would end up looking like the new Defender!
Hi @Flewks I don't have a roof rack on my Grenadier, but I drove a Grenadier with the Rhino at my dealer and had exactly the same experience. The wind noise level was very loud. I then drove the Grenadier with the LeTech roof rack. You can't hear it at all. This is probably because LeTech tested the rack in the wind tunnel and closed the gap between the roof and the roof rack. I have taken a photo of it. Maybe you can do something similar by yourself.
It’s perfectly suitable to drive it with a speed of 160 km/h (100 miles/h)Just test drove a Grenadier and was very impressed by the solidity. Big surprise was noise above 65 MPH. I expected a lot of road noise, but it seemed like the engine (in 8th gear) was the loud part. Didn't have the presence of mind to check RPMs.
Has anyone driven a Grenadier faster ? I drive across Nevada on I-80 a couple times a year where posted speed limit is 80MPH and typical speeds are 85 to 90 MPH. It's possible the Grenadier is not suited for this task, but curious if anyone has direct experience.
Sorry to stick with SAE units! My guess is 800 miles @ 14 MPG => 57 gallons. Gas is priced a bit over $4/gallon through Nevada so call it $250 each way. Airfare would be $500 per person and would be hard to carry all the stuff and the dog. It's America and there hasn't been a passenger train to my endpoint since the 1960s.It’s perfectly suitable to drive it with a speed of 160 km/h (100 miles/h)
But even the diesel will empty its tank within good 3 hours then.
So the drinking habit is by far more annoying than the sound.
I have no issues w/road noise at all either. I’ve driven over 7000 miles in the last 2+ months.Interior noise level is a concern of mine. I often drive Los Angeles to Park City Utah which is about 9 1/2 hours but we also do road trips including off road through southern Utah. It was very comfortable in my full size Range Rover and very uncomfortable in my 2022 Bronco although the Bronco is much better off road.
I have now spent a full weekend taking the entire interior out of the Bronco and installing two layers of sound deadening. This dramatically dropped the the interior noise level. It's now at 70 db at 75 mph. Most of that is wind noise. Has anyone tried installing sound deadening? I saw a video of a Gren with the interior out and didn't see any sort of sound deadening on the vast expanse of metal panels.
This is about mid way through the deadening install... what a complete PIA.
Normally the wind noise is coming from the HVAC when the flaps (actuators) haven’t closed properly. To test to see if it is this, when you’re doing 70mph, switch from Auto to fan speed 1. If the wind noise or whistling has gone, then HVAC. If it persists then it will be something else. Give it a try.@ealshamsi Did you ever figure out the wind noise issue? I am reading the same decibel readings. I don’t have a roof rack or RAI and the Bridgestones are really quiet. So all i hear is extremely loud wind buffeting noise from 70+mph.
I have ruled out the windshield and safari roof by taping them. I suspect the noise is caused by air being diverted through the narrow channel at the bottom of the a-pillar into the door cavity just before the door seal. Or air being diverted into the door cavity from the door hinges that taper to the inside.
I have also done extensive testing with the HVAC, the HVAC is certainly noisy and whistles on the "face + leg" vent setting. However, I do not think the HVAC is causing the loud wind noise described here. I ruled out the HVAC because I taped off the air inlet for the HVAC (the one near the wipers). Unless there is another source of entry for the air into the HVAC, I do not think it's the HVAC.Normally the wind noise is coming from the HVAC when the flaps (actuators) haven’t closed properly. To test to see if it is this, when you’re doing 70mph, switch from Auto to fan speed 1. If the wind noise or whistling has gone, then HVAC. If it persists then it will be something else. Give it a try.
The “G” and new Defender should not be compared to each other regarding road noise as they are “built” very differently/ different audience. Different level of “luxury”/ different market.I've driven the Grenadier on the highway/motorway, and road noise is indeed higher than my new Defender.
But it wasn't unacceptably high, l drove the diesel version.
l didn't exceed 70mph. l wonder if different tyres might improve it for road use.
Agreed.The “G” and new Defender should not be compared to each other regarding road noise as they are “built” very differently/ different audience. Different level of “luxury”/ different market.![]()
