The power steering pump is my guess. Mine was loud at first, but it seems to have gotten a lot better.
Time for some DIY diagnostics:Hello,
I got my Grenadier Fieldmaster few weeks back from Dubai dealer, the car is amazing on-road and off-road, except for one issue bothering the comfort of enjoying the drive.
I have a continues noise coming from the engine, the noise never stops even while parked, driving slow or fast and during off-road, the dealer service center says all Grenadiers has the same noise.
Is anyone experiencing such noise?
You can hear the noise in the attached video.
Time for some DIY diagnostics:Get some 1/2" diameter plastic hose ...about 2 ft. Insert a small funnel in one end.
Open the "hood". Remove the engine cover...(it pulls off by hand) and start the engine and let it idle. Put one end of the tube to your ear and use the funnel end as a "stethoscope" and see if you can isolate the location of the noise more accurately...beware of moving parts!!!
(If you think it may be the serpentine belt, put a very light spray of belt anti squeal on it to see if that stops the noise...)
Hello,
Hello,
Mine is clearly the power steering pump. It goes away after placing in park for about 10 seconds. If you touch the steering it happens again for about 10 seconds or continues if you keep moving steering wheel.A trick I've used for years to distinguish belt noises from pulley or pump bearing issues is to give the belt a few second shot of WD40 or other very light lubricant while the engine is ticking over at idle. (LPS 1 is another option.) Unlike dedicated belt lubricant it will dissipate in a few minutes. If it's the belt squealing do to misalignment or other issue, the sound will return soon enough. If the sound fails to stop after spraying the lubricant you likely have other issues, though with a badly worn belt the sounds may persist. I save the belt lubricant until after the diagnosis.
I see some here have mentioned the induction system as a possible culprit. You could try wiggling some of the plastic intake components around to see if there are gaps or odd connections causing the sound. I'd even remove the air filter briefly to see if that changes anything.
That's a normal noise. I've checked 21 delivered gernadiers to Middle East and it comes from the power steering. Not a single car I've inspected doesn't have this noise.No that is not normal
I haven't srrn a single delivered gernadier that doesnt have this noise. All thr comments here are from folks waiting for their orders to be delivered not actual ownersWaiting to see someone else's car in person which doesn't make the sound, then I'll try and escalate to Ineos themselves as the dealer states it's normal.
All of us do. And every car of the 21 delivered I've inspected do. I've yet to See a single car not make this noise , I'd need a video proof to believe itI’ve got
it
I’ve got the loud high pitched noise and it’s terribly annoying outside the vehicle or while the windows are open.
Ok. Not my petrol USThat's a normal noise. I've checked 21 delivered gernadiers to Middle East and it comes from the power steering. Not a single car I've inspected doesn't have this noise.
Prove it in a video otherwise I ain't believing it . Ou can't convince me that the morning cello that delivered 21 vehicles two months ago all arrived with defected parts.Ok. Not my petrol US
Then don’t.Prove it in a video otherwise I ain't believing it . Ou can't convince me that the morning cello that delivered 21 vehicles two months ago all arrived with defected parts.
