New Member – Excited to Join the Journey Plus Warning Light
TrueNorthGoneSouth
3:18 PM
Hi everyone,
Originally from South Africa, I’ve spent most of my time here in Australia. I’ve recently joined the Grenadier family and am looking forward to seeing where this vehicle can take me as I continue to explore more of this country.
I’m keen to learn from other members, pick up tips, and share experiences along the way. Whether it’s long-distance touring, some off-road adventures, or just finding those quiet places far from the crowds, the Grenadier feels like the perfect fit for the journey ahead.
Shortly after driving my new Grenadier away from the dealership, a red warning light appeared on the display stating "Brake Wear", despite only having driven a few kilometers. I turned around and took it back to the dealership, where they briefly inspected the issue. They mentioned it wasn’t life-threatening and assured me they’d follow up at the start of next week. However, I didn't hear back from them. Has anyone else experienced this issue, and if so, what was the outcome?
Looking forward to being part of this community.
Cheers.
anand
10:18 AM
Maryland
I would check the right front (driver's front) brake pad wear sensor harness and brake line as they have been known to not be installed properly (and often this is missed whilst doing the pre-delivery inspection at the dealer). The failure is from rubbing on the inside sidewall of the tire.
Turning the steering wheel all the way to the right will give you a clear view into the area and you'll be able to see clearly if that is it or if there is something else going on
How long have you had the vehicle for? I would certainly follow up with them
TheDocAUS
2:18 AM
Eromanga
Welcome aboard
1. Download and use the Rok Dr Guide here.
2. Grenadier Accessories for you to buy here;
3. Kanvas bags and products here;
4. Information of Deutsch DTP plugs here;
5. Learn more about the CTEK SMARTPASS 120S and 250SE here;
6. Littelfuse FHZ busbars used in the Grenadier here;
7. Various recommended torque settings here; and
8. L track information here.
No such thing as a dumb question on the forum, we only ask you do a search first.
TrueNorthGoneSouth
3:18 PM
Welcome aboard
Many thanks for the above :)
TrueNorthGoneSouth
3:18 PM
Thanks for your suggestion. I took some photos of the right front brake pad area yet I'm having trouble uploading them here so I'll sort that out tomorrow and hope that you are able to point me in the right direction as I'm not exactly sure what I am looking for.
anand
10:18 AM
Maryland
You would see a black cable, attached to a silver stainless steel braided brake line rubbing on the inside sidewall of the tyre; if there is more inspection needed than that, you have a different issue (perhaps a failed pad wear sensor)
