Build Thread My Grenadier Trialmaster Utility Build
8:39 PM
Well that's reminded me of something I'd forgotten!
Shouldn't void the warranty with that mod 😁
Znarfgh
8:39 PM
Melbourne
SIDE STEPS
Time to start work on the side steps. Will try a design using 50x25x3 RHS for the steps and supports and 4mm plate steel for the mounting plates. The weight should be around 12kg per side which is fine. These will be steps and not rock sliders.
I need to make an L plate for the centre support and will then test the step for strength.
Znarfgh
8:39 PM
Melbourne
BATTERY MONITOR
I have been using a twin voltmeter to keep an eye on the battery voltages but decided to purchase something a little more useful. https://www.ebay.com.au/itm/1957192...pid=5338980679&customid=&toolid=10001&mkevt=1
Installed one on each battery, charged both batteries to 100% and then compared the vehicle readout to that of the monitor.
As others have found, the vehicle gives a different reading to the monitor.
The vehicle says 82% and the monitor 99%. As a test I will let the battery run down to 50% SOC and then compare the vehicle to monitor readout.
Znarfgh
8:39 PM
Melbourne
SIDE STEPS
I worked out a design for the side steps using RHS and some rudimentary welding skills - should be around 20kg per side and do the job.
Materials should come in around $300 and a LotsaDollars for my labour (I'm more a woodworker than metal fabricator!)
Znarfgh
8:39 PM
Melbourne
SIDE STEPS
The side steps make a huge difference to getting in and out of the vehicle. Temporary coat of paint till I decide on the final finish. These should have been the very first modification on the list.
I don't think they will stand up to rocks well but if that does eventuate, I'll build a different set.
Znarfgh
8:39 PM
Melbourne
COMPRESSOR
That portable ARB compressor needs to be hard mounted.
I made up a mounting plate, modified the ARB plate from the portable box and it all fits nicely behind the second battery. I will remove the outlet with a T fitting and put a second outlet on the passenger side. This just makes it easier to get to the van on the passenger side.
Wiring etc. still to be completed but will use the power supply located to the left of the compressor.
Znarfgh
8:39 PM
Melbourne
I have a Gator rearview mirror with the straps and because of the positioning, interferes with the airbag warning on the overhead console.
After some searching, I found a Universal mount that looked like it would fit and ordered it.
The fit is not 100% but a little modification made it work.
I decided to remove the complete OEM mirror and was left with this.
I had this RAM mount lying around and it holds onto the mirror nut just fine.
Add a couple of these and a 18mm hex nut:
And, I have a new mount
No more clearance issues and I can now actually use the mirror part if I so choose
No more clearance issues either
