Build Thread My Grenadier Trialmaster Utility Build
Well that's reminded me of something I'd forgotten!
Shouldn't void the warranty with that mod 😁
SIDE STEPS
Time to start work on the side steps. Will try a design using 50x25x3 RHS for the steps and supports and 4mm plate steel for the mounting plates. The weight should be around 12kg per side which is fine. These will be steps and not rock sliders.
I need to make an L plate for the centre support and will then test the step for strength.
BATTERY MONITOR
I have been using a twin voltmeter to keep an eye on the battery voltages but decided to purchase something a little more useful. https://www.ebay.com.au/itm/1957192...pid=5338980679&customid=&toolid=10001&mkevt=1
Installed one on each battery, charged both batteries to 100% and then compared the vehicle readout to that of the monitor.
As others have found, the vehicle gives a different reading to the monitor.
The vehicle says 82% and the monitor 99%. As a test I will let the battery run down to 50% SOC and then compare the vehicle to monitor readout.
SIDE STEPS
I worked out a design for the side steps using RHS and some rudimentary welding skills - should be around 20kg per side and do the job.
Materials should come in around $300 and a LotsaDollars for my labour (I'm more a woodworker than metal fabricator!)
SIDE STEPS
The side steps make a huge difference to getting in and out of the vehicle. Temporary coat of paint till I decide on the final finish. These should have been the very first modification on the list.
I don't think they will stand up to rocks well but if that does eventuate, I'll build a different set.
COMPRESSOR
That portable ARB compressor needs to be hard mounted.
I made up a mounting plate, modified the ARB plate from the portable box and it all fits nicely behind the second battery. I will remove the outlet with a T fitting and put a second outlet on the passenger side. This just makes it easier to get to the van on the passenger side.
Wiring etc. still to be completed but will use the power supply located to the left of the compressor.
I have a Gator rearview mirror with the straps and because of the positioning, interferes with the airbag warning on the overhead console.
After some searching, I found a Universal mount that looked like it would fit and ordered it.
The fit is not 100% but a little modification made it work.
I decided to remove the complete OEM mirror and was left with this.
I had this RAM mount lying around and it holds onto the mirror nut just fine.
Add a couple of these and a 18mm hex nut:
And, I have a new mount
No more clearance issues and I can now actually use the mirror part if I so choose
No more clearance issues either
PORTABLE BATTERY BOX
Given the unconventional dual battery setup configuration, I decided to add a LiFePO4 battery, DC-DC charger, Bluetooth monitor and battery box to the Grenadier.
It's just a generic battery box purchased off Ebay with a few modifications to suit my power needs. I changed some of the output sockets, the battery disconnect button and the power in socket to a three pin Anderson which takes care of the ignition trigger wire and allows for quick connection. I removed the high output 120A Anderson plug and replaced it with the triple Ando as I have no need for the large Ando which I think was meant for jump starting.
I mounted a 40A DC-DC charger inside the box and put a small window in the lid so I could monitor the charger lights.
The yellow Anderson plug is for a solar panel connection. All my consumers like fridge, additional power outlets, reversing mirror cam and other charging points run off this battery and the original dual battery is pretty much the same as it came from the factory. When the EFB batteries reach end of life, I will reconfigure the system and make use of the space where the current second battery is located.
I used a "Chuckwagon" system from a previous vehicle as it has always worked well for me and after all, if it ain't broke...........
Drawers seemed to be a better option to the blue spacecase and I built a set of storage drawers and a spot for the battery box that I use to run all my consumers.
In with the fridge and drawers. Gas cooker and billies in the shorter, lower drawer, food and miscellaneous items in the top, full length drawer.
The lid needs a tidy up but that's not urgent. It's not new and pretty, but well relatively light, proven and works well for me. Still to come are water storage and a shelf in front of the unit.
Reactions: IGL
